I usually use my lights outdoors as I love Mountain climbing/Hiking/Camping and wanted to know what budget light is the most durable and can withstand minimal outdoor abuse. My tank 566 has been very reliable and has withstand 2 drops for more than a meter but suddenly went bad after the 3rd drop.
Very tough question. The QC on most sub $20 lights is such where you may get one that can get absolutely pounded on with no effect while others a single drop will make it stop working though they are the same model. However, those that break are usually repairable if you have the time and basic skills (Wire breaking free from the star is a common result of drops and once it is resoldered, it works again). Picking a model that is consistently durable from sample to sample is what makes this tough. Probably sticking to a simpler light or a light from a manufacturer that is known to be a little better on quality control are your best options. The fact that you want multi-mode makes it tougher as well. Lights that I think would be candidates are:
i like the tank alot . i just need a good reason to go in and put a neutral xpg r4 emitter in it ... fix it
much easier to fix and upgrade the emitter ..if you want it really really rugged you could pot it ..basicly termally gluing the entire emmitter and driver in place ..put a real sweet tint in it because there's no opening up ever again ...;)
Thanks for the reply, I actually done fixing the Tank007 and have tried changing the emitter using a neutral tint (I used a lot of force removing the head). I replace back the LED when it stills flicker, but after doing so (with cleaning and using a deoxit) the light seems to wok fine again and stop flickering but now it has the OLD LED back which I'm thinking if the light deserves the neutral R4 LED.
I really love the light but for a camping Light I need it to be the more durable. My Tank E07 seems perfect if only it have a lower mode.
Anyways what will be the output of the Tank 506 if I will replace the emitter with an XM-L T5 led and not replace the driver?
that's why i glibbly tossed out .. the fix it idea .. I'd love to have a broken one ..so i could try and get it open .. if you break it you have nothing to lose . i'd research every trick on how to open tough lights ,and them give them a try ..why not ? ... breaking stuff is right up my alley
.. oops ..EDIT:
Before I even posted this I went out and stuck this light in the vise after wraping it a few times with a towel .. there's cut outs on both sides so the tube will never spin in the vise .. I wrapped the head with strips of that thin no slip padding you can use under carpets or in kitchen cabinets. I use them to open tough jars too. I used a piece of that around the head and then wrapped a few times in a strip of cloth around that and broke out the channel locks .It popped free so fast i wondered what I ever thought they were tough to open besides it just being a slick light ... that was easy now what ?? ..NEXT >>>
I think that’s a dang good question … it depends on the amps it’s pulling … mine is doing .85 high .21 med. .4 low on a 14500 at 4.0 volts… since the emitter wants 3.6 ? 3.7 ? we can assume it’s putting 1 amp to the emitter modes are 100% 25% and 5% i think the mode spacing is good on these lights …
my guess is the xml won;t have a higher output than an xpg at one amp. and won't be any more efficient ..barely at best .. would drop the neutral in it in a heartbeat and wait on a nice 1.5 amp driver with no pwm like this one has
My question is about the vf <<I don't understand vf at all .. don't know nutting about it other than xpg's and xml's have lower vf ..what that means is beyond me .
my guess is it will do about 300 lumens at 1amp and impress the hell out of you ..
Question is can you just change the emitter and not the driver and what's the output ??
Lets wait for smarter people to answer this question ..
Is the Xeno E03 XM-L durable enough for outdoor usage? Just Got my second Zebra SC50 but still need that budget light to bring to my outdoor adventures, easy to fix and cheaper.
By the way I started my light collection (online purchases) by getting the Romisen RC-G2 from deal extreme from 2009 and now its upgraded to warm Led and sitting as my shelf queen, I really love the light and has been super reliable. Don't have a backup light that I EDC back then, now I carry 2 at least.
Actually when I saw the title I was going to recommend the Tank007 TK-566 to you. ;-) I'm usually pretty careful with my stuff, but one time I handed my TK-566 to somebody who promptly dropped it from about 1.5 meters onto cement. Except for a few tiny paint chips, it's no worse for the wear.
Good question. Its put together well, but its smaller, thinner than some other 1xaa lights (My ITP C7 has at least twice as much metal in it, but you pay for it in weight and size). The bezel is stainless steel which should provide some protection on drops and I think I read somewhere that Xeno did do drop testing on it. However, I am not one to intentionally torture test a light and my Xeno is not really in a duty situation where it would regularly take abuse. Unless you really beat the snot out of it, the Xeno does come with a 3 year warranty however, so Tactical HID will repair it free, although you have to pay to ship it to them to fix.
I was going to vote for the Xeno but it is twice the $20 budget that the OP mentioned.
I don't think any of us really know the answer to the OP, because we don't stress-test out lights, in fact I don't think anyone does. I'd say for $20, buy the 4x AA Dorcy yellow light. Probably your best bet, compared to an aluminum light. That is the direction I would go. Also look at the Coleman "Max" products that are Polycarboniate.
For those that don't know, I work in maintenance/engineering for a large steel mill. Up to this point, the operators (guys on the deck....around molten steel and heavy equipment) have been using 4xAA incan Pelicans. They have failed at an alarming rate. Granted, these guys are extremely hard on all the equipment they use...more so than any police officer or firefighter I've known (quite a few...). If you've never been around a 150MW DC arc furnace, it's a sight to see...and one of the harshest work environments out there.
About 4 months ago, I was talking to the operations supervisor and he was complaining about the replacement cost of those "damn pelicans". I casually mentioned a cheaper LED alternative that was 1/4 the price and only used 1 aa, yet would be brighter (didn't mention durability because I wasn't sure myself yet). He bit, and an order was placed that day to Shiningbeam for 100 Romisons (RC-29's and RC-G2's). Of those 100, I've had 4 come back to me broken. 3 of them were rc-29's where the pill had unscrewed itself from the body due to constant switching from flood to throw. A simple fix with locktite cured them. The one rc-g2 that has come back had a broken connection on the coil to the driver board. A simple solder fix. I've seen quite a few of the others hanging from there lanyards off of the guys belts. They look beat to hell and back, which is no surprise considering the abuse they go through. Despite that, only 4 needed attention.
I feel that I wouldn't have seen any of them if two extra steps had been taken. Those would be locktite on the pill threads, and the pill potted.
So, take this info for what it's worth. A sizable sample of the same lights that are all abused daily, and with a fellow flashaholic present to observe. I'm not going to say that these romisons are the most durable around, but I wouldn't hesitate to bet on one (especially if given a little attention at first). Only one mode, but could easily be swapped to a different driver (and potted at the same time).
Tough little lights.... that's all I have to say about that.
p.s. - forgot to mention one poor rc-g2 that took a half gainer off of the overhead crane rails, which are 110 feet in the air....it still works.
Potting usually means adding a flexible epoxy material for improving shock resistance of electrical components. thermal epoxy would probably work well for this purpose. ive seen them in different color on electrical parts.
I Just bought the Xeno from Ebay(HKequipment) for $32.00 and actually its also available in their website for $30 without insurance and $32 with insurance.
I myself was able to distinguish which of my lights are durable enough due to usage overtime (more than 3 months usage which includes accidental drops). I love my RC G2 and Tank007 E07 but both are single mode. I ask Bryan from shiningbeam if he could sell me a 3 mode version of the RC-G2 but he can't and instead advised me to buy a new driver for it which he also sells. I'm reluctant on moding my lights with new driver as I tried that before and destroyed one.
I actually have several lights that is durable like the Solarforce L2r and L2i but it requires multiple batteries and Now I'm going lightweight for my next hiking trip.
Many. Jamesearljones got it right. If I'm certain I won't be going back into the pill it gets potted. The lack of a tutorial is probably due to its simplicity. For a flashlight, all it involves is filling the void in a pill with non-conductive thermal compound. I've used both arctic silver epoxy and fujik thermal glue. Basically fill the inside of the pill with however much you think you'll need, then seat the driver. If it just barely starts to come out of the wire holes in the top of the pill you got the amount right! For extra shock protection, add a bit to cover the wires connecting to the emitter, since they tend to pop off (although this is more due to poor soldering). Pro tip: make sure the wires are all the way through the correct holes and are long enough before seating :)
I may do this with an extra rc-g2 I have at work.... Change the driver to a 3 mode, pot the entire thing, and seal all the threads sans tailcap with locktite, then give it to the roughest operator at work I know....
For clarification, I'm not stating that I believe the romisans are the toughest budget lights out there....but only the toughest I've had personal experience with on a large scale.
Thanks Match. I guess I was reading too much, about how you need different materials, have to worry about thermal expansion snapping off components, should mix alumina into the epoxy to increase thermal transfer, etc etc.
If I can just glub glub it full of (more or less) household epoxy, that's great!
