Let me second that thank you. I used the database yesterday to find the best place to order some xml2 u2 1a's. Big time saver.
You just caused me to spend 2 hours searching emitters
Yes.
This thread has now been made, and Hank (from IOS) confirmed it.
Thanks for the feedback Bigwood and ImA4Wheelr! :beer:
Ice, huh?
XP-G2 R5 1A is now cheaper @ FT
http://www.fasttech.com/products/1609/10001905/1311505
http://www.fasttech.com/products/1609/10001905/1311504
2,41/2,41$
2,19$ a piece if you buy 3. That is cheap!
Cool. Thanks RaceR86. Just purchased 5. Also ordered that 100mm aspheric lens. Can't find any reviews of it.
http://intl-outdoor.com/noctigon-3xp-mcpcb-cree-xpg2-r5-2b-leds-p-764.html
http://intl-outdoor.com/noctigon-3xp-mcpcb-cree-xpg2-r5-3c-leds-p-765.html
Added MT-G2s from IS, 20.5$, mounted on 20mm mcpcb : 5000K - 3000K 90 CRI
I have a feeling the "5000K 80 CRI minimum" and 4000K 80 CRI minimum would have sold better... (you listening IS)
Nichia 219 is on sale 3,5$$ bare or 4.88$ mounted on 10mm mcpcb
From Simon@Aliexpress (aka Alixexpress SGWT ) I have added a bunch of emitters, and updated several prices. All his XM-L2s are now on discount and have been for some time. Compared to earlier (summer time) , he has now got a great selection again. Several emitters that was sold out very quickly in the past..
Notice this T4 6A3 80+ CRI. Nicest Cree "6" tint you can get if you ask me.
Thank you RaceR86. Couldn't resist the T4 6A3 and ordered 5. Looks real good on that ANSI chart.
This caught my eye looking at simon’s selection. Seems to be a genuine XML U2 –3C NW. Never seen one of these tint/bin combinations before and might be the best option for getting max NW lumens out of a single cell light. Potentially easier to drive harder than an xml2 T6-3C and get more total output? Might be interesting to test.
I have purchased some of those from Simon this last summer. I don't have test equipment, but they seem like the real deal. I reported on them in Post 206. I have one in a light and I like the tint. Seems to be the same tint as the xml2 t6 3c's I have.
I have two xml2t5-3c from illumination supply used in a work/floodlight and this is my definition of neutral white…
I just used a Cree XM-L2S6, 7D3 Tint with 90+cri from IS.
https://illuminationsupply.com/bare-leds-c-52_36_88/cree-xml2-bare-s6-7d3-tint-2900k-90-cri-p-615.html#.Um6Gw7K9KK1
The colours are superb but for me it is a bit too “warm”
I guess there is not much differents between the xml2t2 from Simon and the 7d3S6 in tint…so I probably order one of the 80cri XMLs from iOS to come closer to my wishes.
Sounds good, I will probably order some for NW thrower projects. I hope they’re not too green. I would have expected extraordinarily high output bins in the 3C bin to be at the extreme end of that tint quadrangle. Kinda like those early cool U2/U3 bins that were only available in the 2S/2T range.
I'll try to remember to double check tonight, but I don't recall any green tint. Seemed more like beige if I remember correctly. I intend to use them in single cell lights that I want to push hard, but not dedome. I don't know if the output is any higher (probably not), but I'm able to get higher currents with xml's (vs xml2's) in single cell lights.
That’s exactly the same use I had in mind. Gotta snap them up while they’re still around
Tints are so subjective and relative it’s hard to really describe them to someone else I find.
I have one particular T6-3C from a reputable source that has just a touch too much green tint to it for my liking. I classed that one as probably being situated somewhere in the upper/greener part of the 3C tint quadrangle. Other 3Cs I have are nicer/more neutral and probably closer to the BB emission line.
Speculation mode = On
My NW 5000k tint reference is my Apex 5t6 which is a very nicely balanced NW tint, neither too green nor too pink/purple.
While listed as containing only T6-3C emitters I’m sure it’s really a scatter shot combination of all the 3x (3A,3B,3C, 3D never seen one but maybe it exists) tints which gives the nice blend. This is how cree generally ships emitters in bulk so it makes sense, especially in a budget light.
If I isolate the individual emitters and take comparison photos, I get ones that are close to the greenest 3C tint I mention above, a rather cooler more purple tint that matches a 3A I have and everything in between. Including one really nice, slightly warmer emitter with no hint of green that I would guess is very close to the BB line and almost a 4B. If all 3C emitters were like that one I’d be delighted
I imagine this is what the general tint distribution looks like when Cree cook up a batch of NWs
This is pure speculation on my part, just based on the rather limited samples of 5000k NW emitters I’ve seen and compared and what’s been available on the market over the last couple years. Would make sense to me to see a trend similar to this though and it might explain why 3Ds are so rare/nonexistant
I would also expect the higher output emitters such as these U2s to be right at the top right of that blue line.
Speculation mode = Off
That's interesting. Never noticed, but I believe you are correct. Lots of people say the 3C's look too yellow. Which is consistent with the area above the BB line in 3C above.
Now I'm curious. I'll check my one installed emitter tonight and report back. I have only used it outside and haven't tied to determine if it was 3C after installing it. I only remember noticing that I found the tint acceptable and was relieved that it seemed similar to my xml2 3c's (which I like).
EDIT: Examined the tint. It's so green out here (vegetation) I had to go inside and use white walls. You are right, there is some green in the tint. I still find the tint acceptable, but I definitely wouldn't want to dedome this emitter.
If you have already ordered some of these, Simon will likely work with you to cancel the order. After Aliexpress verifies your payment, a "Cancel" button will appear next to the order. You may want to send a message to Simon ahead of time letting him know your intentions.
Thanks for doing the check and verifying my thoughts, I haven’t ordered the emitters yet but will probably still give them a go.
They’re going to be used in thrower projects anyway and there a bit of green is ok by me. In fact I like some extra green for scanning vegetation outside, gives much better contrast than more neutral tints.
I was just interested to see if my tint speculation was holding water with these emitters, trying to get as much of the “blind luck” out of picking emitter tints
I really wish Cree would start doing 4 or 2 step macadam binning for XML 5000k NW emitters like they do with the MT-G2. Then you know you’re getting a very tight tint classification very close to the ideal BB line.
Cheers
Edit: More speculation mode…
If my theory on NW tint yield/distribution follows that blue line then the best chance of getting a tight tint classification closest to the BB line is with the 3B tint. Since they seem rather rarer than 3C and have less of a chance of being overly green than the 3C while not extending below the BB line as with the 3As. I have a 3B that I really like, slightly cooler than the 3Cs but almost no green, maybe I should pick up a few more and compare to see if this theory holds true.
XM-L2 U2 1D on Noctigon (slighty less cool compared to 1A)
16mm, 6,79$
20mm 6,89$
Sinkpad from LCK-LED
XM-L 16/20mm 1,75$
XP-G 16/20mm 1,75$
I have never considered Kaidomain a trustworthy source for emitters. Especially not since they have a tendency to always claim top bin. And maybe mess up tints about too?
But look what they have added!!!! In B11 bin.. (so they say)
Nichia NVSL219A-H1 B11 LED 14.5 x 1mm Star (92 CRI, 4500K) 3,49$
And there is more Nicha 219
Nichia CRI92 NVSW219B-E R85 B200 LED 14.5 x 1mm Star 3,79$
Nichia NVSW219B-T B280 C1 L2 LED 14.5 x 1mm Star 3,71$
Nichia NCSW219B-E B15 C1 LED 14.5 x 1mm Star 3,49$
Anyone familiar with the other Nichia 219 emitters??
Oh, and the old and classic XR-E, in NW tint 3,29$
From IOS:
XM-L2 U2 1D bare emitter, 4,98$
