Been flying since I was 10, and there is nooooo way id start with those micros or jets either
I have been thinking about getting my brother into it, and I think the cheapest way is something like this:
Gliders fly sooooo slow so you have time to correct your mistakes. Being a pusher prop it wont break the prop on landing, which even folders do, and its repairable with foam safe CA for probably 10 or 20 crashes. I fly mainly foamies now because theyre dirt cheap and super easy to fix and modify. One day when I get a piece of land big enough, ill get back into bigger ones etc.
That would get you started anyway.
The dx5e is ok, I have a dx8 and a dx4 that came with a rtf kit which cost almost nothing, and a few old 72 mhz futaba computer radios etc.
The ones that come with the hobbyking kits are fine. Ive had one similar for probably 5 years and it never skipped a beat. Although my futaba is 20+ years old and still works perfect too.
If I was going to buy a radio to start off with, dx8 is awesome, dx7s is just as good but often you can find the dx8 cheaper, and the dx6i is what I would buy as a minimum, because you can save 10 models on it, the dx5e can only save the one. A PITA to re set up everytime etc once you get into it.
I also use these receivers which have flown great for the 2 flights so far haha
If that helps!
Chris
