Awesome review, I love the addition of the infrared pictures. Bit strange that it sometimes terminates early on NiMH cells at low currents. Although the table at the start of the review only mentions 0.5A for AAA and 1.0A for AA as supported charging currents.
I wish that this review was available BEFORE I bought the XP4 :(…
Having said that, I’m a little confused about the Nimh charging thing. I thought that, based on the CPF thread that I got referred to awhile ago, that if the current was set to 0.5amps, that termination was ok with AA Nimh batteries?
That (using 0.5amps with AA Nimh) has been my (limited) experience also, after initially trying 0.25amps with AA Nimh, and then later switching to 0.5amps with AA Nimh…. seems to terminate ok, and doesn’t heat up the batteries and the charger anymore?
As always a very good review, it seems again the NiMh termination of a combo charger is problematic., hopefully they can fix this in final production, I would like to replace my NiteCore i4 with an adjustable current charger.
I was never happy with my i4 charger with NiMh charging , so went and bought the AccuPower IQ-328 8 months ago and the clone from DX, both do excellent jobs with NiMh , I test my NiMh cells after charging on my ZTS analyzer , and they are always fully charged.
Thanks for the review, I was holding my finger on the “BUY” button but now I am disappointed, it was supposed to be my main eneloop charger
Not going to buy it obviously.
as i said, it is no problem. just insert 3 or less cells :)
otherwise it is clearly a charger error :p
HKJ, is there an auto restart feature for LiIon's like the 3.9V threshold of the WP2s? my 10440's have dropped below 4.1000V within 24hrs in the charger and the charger has not started the recharge yet omg! :|
I was using my XP4 to charge some 18500s (6 of them) tonight, using the 1.0 amp setting, and they all came off the charger at between 4.16 - 4.17 volts.
Is that ok? It seems a little low…
Does the XP4 have problems terminating Li-ion too soon also?
4.16 to 4.17 is ok, it will depend on the age of the battery and the charge current, using a lower charge current will get you a slightly higher voltage (Because the termination current is less).
