Review of Charger Xtar XP4
Exceptionally good review as always!
Thanks..
Superb review, like always.
I would rate this a “hot” charger… :wink:
I wish that this review was available BEFORE I bought the XP4 :(…
Having said that, I’m a little confused about the Nimh charging thing. I thought that, based on the CPF thread that I got referred to awhile ago, that if the current was set to 0.5amps, that termination was ok with AA Nimh batteries?
That (using 0.5amps with AA Nimh) has been my (limited) experience also, after initially trying 0.25amps with AA Nimh, and then later switching to 0.5amps with AA Nimh…. seems to terminate ok, and doesn’t heat up the batteries and the charger anymore?
It has no problem terminating, the problem is that it terminates before the batteries are full.
Check the blue line in the charts, with eneloop AA, it is supposed to reach a bit above 2000mAh. There are curves where it only reach 1300mAh.
NiMH batteries are supposed to heat up a bit, when they are near the end of charging.
I guess that I need to get a dedicated Nimh charger then :(.
Does it hurt (lower lifetime or whatever) Eneloops to undercharge them like that?
EDIT: Been thinking about this one:
http://www.amazon.com/AccuPower-IQ-328-Battery-Charger-Analyzer/dp/B004Z5XXZU/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=1EFBQBHFZ1JBX&coliid=I7ISSRTWXHZUT
AccuPower IQ-328
No. But if you are using batteries with different charge level in series, you might hurt them (Reverse charge).
As always a very good review, it seems again the NiMh termination of a combo charger is problematic., hopefully they can fix this in final production, I would like to replace my NiteCore i4 with an adjustable current charger.
I was never happy with my i4 charger with NiMh charging , so went and bought the AccuPower IQ-328 8 months ago and the clone from DX, both do excellent jobs with NiMh , I test my NiMh cells after charging on my ZTS analyzer , and they are always fully charged.
Thanks for the review, I was holding my finger on the “BUY” button but now I am disappointed, it was supposed to be my main eneloop charger :expressionless:
Not going to buy it obviously.
Superb review by HKJ as always, nice addition of thermal imaging as well, cool toy equipment you have there :bigsmile:
Well, I just removed XP4 from my FT cart after reading this review :weary:
Thank you, very informative!
Yes, heat is transferred from the charger to the batteries.
Here you can see a curve from a NiMH battery, without any external heat sources (Charge rate is 1A):
Yes, the heat problem is clearly a user error! :stuck_out_tongue:
as i said, it is no problem. just insert 3 or less cells :)
otherwise it is clearly a charger error :p
HKJ, is there an auto restart feature for LiIon's like the 3.9V threshold of the WP2s? my 10440's have dropped below 4.1000V within 24hrs in the charger and the charger has not started the recharge yet omg! :|
Yes, there is a restart level, but it was to close to the termination voltage to get a good reading of it.
Are we talking about LiIon?
True, termination voltage of Eneloop AA and AAA at 0.25A and 0.5A is sometimes 1.38xxV or even below 1.3800V.
But my question referred to LiIon. I don't see any restart near 4.1V
Hi,
I was using my XP4 to charge some 18500s (6 of them) tonight, using the 1.0 amp setting, and they all came off the charger at between 4.16 - 4.17 volts.
Is that ok? It seems a little low…
Does the XP4 have problems terminating Li-ion too soon also?
Thanks,
Jim
4.16 to 4.17 is ok, it will depend on the age of the battery and the charge current, using a lower charge current will get you a slightly higher voltage (Because the termination current is less).
Xtar chargers usual works very good with LiIon.
Hi,
These were all 18500s from an older, but “new” laptop pack, supposedly about 1700 mAh capacity:
I’ll try using a lower current next time, but would you recommend 0.25 amps or 0.5 amps charge rate for these?
Thanks,
Jim
I will not recommend it, but if you need the maximal capacity a 0.25A charge is best (The termination current is about the same on 0.5A and 1A, i.e. you do not really get anything extra at 0.5A).
Do not expect much, you get maybe 1% extra.
