There are some HD2010s that come with the original EAST-092 driver, which was the “good” DD driver.
Nowadays, if you get an HD2010, you sometimes get one with one of the “good” EAST-092 drivers, and sometimes not. I had to try several times, from Tmart, before I got one with a “good” EAST-092 driver.
I don’t know if anywhere sells HD2010s with guaranteed “good” EAST-092 drivers.
Can’t believe I missed this! Are you, by any chance, going to make any more? Being as how they sold out in the first few minutes. lol 14 posts and they’re gone. Wow!
Pllllleeeeeeeaaaaaasssssseeeeeee!
I’ll never work on a light again, I’ll hover over BLF with PayPal open and ready, forevermore… oh, wait, I kinda already do that! My bad, carry on.
Well as I was the first loser in this mad scramble, I will be in for one if you decide to make another run.
Either way, thanks to VOB for making this available to us. I am looking forward to see some nice mouseover pics with before and after on these soon to be hot rodded HD2010’s.
I did not see any measurable improvement in lumens or throw from the upgrade, over a brass C8 pill with copper inserts, but the host seemed to heat up quicker, so appears to pull the heat away from the LED quicker. This was at 3.85A - maybe there is noticable improvement at higher amps.
On that pill, all I used was AS5 - nothing was used to lock it into place. If I was to do this today, I'd look into drill+tap the pill, secure with screws - it's a bit of work to center and insure clearance for the screw heads, but I like the idea the star can't inadvertently twist and cut wires, and of course has a better thermal bond connection. I try to eliminate sharp edges around those wire holes by filing/sanding just in case.
Thanks for running these, wow what a quick sale. I’m looking forward to pushing one these with a direct drive. It looks like you could get rid of about 20-30 more just about as quick.
Of course there is. Its a better thermal transfer. Better by how much in real life.. cant say, not that much. But if you can do it easily, just go ahead.
