Tom E measured no appreciable difference between a copper c8 pill and a brass equivalent, there’s pretty much your best and worst case scenario, I can see replacing alu with a more easily solder able alternative but its not going to magically improve your light over the improvements a direct bonded copper star will make, and its just as easy to silver solder a copper star to a brass pill as it is to solder a star to a copper pill, you still have a junction there and lead/rosin solder is a pretty crap thermal conductor tbh.
Good luck with this either way, I just don’t see the benefit, I’d love to be proved wrong but there’s nothing yet.
Personal experience tells me that the copper pill will take much more heat away from the star than an aluminum one will…all other things being equal. I have soldered connecting wires to the copper star on my HD2010 pill too many times. With this light I have learned to mod. It’s not really difficult to solder to the star when it’s on the stock aluminum pill. But, after I put 1/2” of copper in the core of the pill, cutting out the middle of the pill so that the copper star is sitting directly on top of the copper….my Hakko 888 station is taxed to solder on it now. So for me it’s fairly easy to see that the addition of a mass of copper to the pill has greatly increased it’s thermal absorption rate. If it sucks the heat out of my soldering iron set to 1000º F, then it will also suck the heat from any emitter I put in there.
A full copper pill would give even more benefit, as it carries even more mass.
Edit: I have also made light engines for the L2P consisting of a 7/8” diameter copper rod 1” long. The star is re-flowed directly to the top of this chunk of copper. If I don’t put some solder paste on the connection pads when I’m doing the reflow, I will not be able to solder the wires onto the star later. My Hakko goes to 1100ºF, it won’t do it if the star is not pre-tinned.
That’s about 3 ounces of copper. Overkill? Beyond me to say. Many of us do things the way we do simply because it’s what we want/like/believe. Works for me.
@DBCstm: Its all correct what you say, but gords main point was that copper is not better than brass. There is enough data to back that claim, though I disagree with lead being a bad conductor. Its about 8-10times better than Arctic Silver.
The main benefit of copper is, that it can extend your runtime on high in lights that are too small to handle the heat, because it takes longer to saturate the heatsink. Downside of that is, that such lights will take longer to cool down.
I'm an ultralight backpacker and (sports)car guy. Paying for slight mods to gain an edge in performance that's barely perceptible at best is part of the game.
You may be right though, but that's part of the reason I'm asking for slight design changes that will have tangible benefits.
Testing of a copper star on Alu, Cu and Ms (brass) heatsinks.
What matters is the thermal properties of the first material after the LED - the PCB. After that, its pretty much irrelevant. Seeing how good brass performs, a heatsink made out of solder would still work great. See how aluminium gives a lower temperature reading than copper, although the thermal conductivity of copper is higher? Thats because there are other values to consider.
whilst the pill may absorb more heat, it still has to shed it through the threads, increasing the mass/using a different material merely gives you a bigger heat store, it doesn’t necessarily translate to an ability to allow the light to shed more heat.
I guess thats the point both myself and nightcrawl are trying to make.
yeah, all that copper will make it harder to solder to the pads, but it still might not get more heat out of a light, and that is really the aim here, myself, I’m just happy if a pill is brass rather than alu, and really, according to the facts above, I should be gutted if this were the case.
If that is so, where is all the heat from my soldering iron going when the copper is present under the copper star, as compared to when aluminum is present under same star? Why does my light run much cooler at more than 2A more energy consumption when the copper is present?
Perhaps the test was done in open air and the heat sink had an easy job of it. In a confined environment like our lights, it’s not as simple as that. The test results shown above do not make any sense, but then I am not an Electrical Engineer. I just build excessive lights in small packages and use copper to do it. It works. 1800 lumens in a 4” light from an 18350 cell. So I stick with what works.
Sorry, it just throws me as a relative beginner when someone first goes with one theory, then aludes to another. NightCrawl used copper for a heatsink in a fantastic build of a quad earlier this year, and is now saying it wasn’t necessary. I get lost easy I guess, comes with old age and meds.
the heat goes there… to the copper. once you apply enough calories to raise the temp to the melting point, you will be able to solder it. you must have in account the calories lost in the surface of the copper chunk, but most of the heat is being accumulated in the copper, because it doesnt have a very good cooling design. in fact i think it hast the worst possible design, IE smaller surface possible
That's important to me. I still want to use lots of current even in small lights, or big showerhead lights. I only use the high mode for short periods, so it's okay if it takes a while to cool down so long as it's able to soak up the heat in the first place.
It'd be nice to see these copper pills made to maximize thermal mass. That's what I liked about how MRsDNF designed that HD2010 pill. It could even cost the machinist less to make, if for example the driver walls are kept as thick as possible.
Where was the temperature being measured for that test?
Copper has a higher specific heat (as well as higher thermal conductivity) than aluminium, so while there might not be much temperature difference, the copper can absorb more heat before increasing in 1C in temperature.
I don’t think it would take too long. As soon as we finalize a design, I’ll probably be able to finish them in a week or so.
I am interested in the copper pill for the HD2010 if you manage to get that made. I will almost certainly also buy one from Matt, but will probably get another HD2010 to experiment with. The one I have is unbranded. Will be interesting to see if there are better ones out there.
It’s always going to be a competition, because of the passion.
Most of this I just really don’t know the answers. But I’m enjoying building my own lights or modifying ones I have that seem to be under performing so I want to know what the best direction to take is. Don’t wish to waste my efforts or my money, ya know?
Well, let me ask then…is it your intention to merely duplicate the OEM pill in a better grade of material? I’d like to see the pill have thickness under the star, don’t understand why the extra machining steps are taken to hollow out the pill when it could be left as solid as possible. Unless that air space has some advantage that I’m missing…
I was thinking the same thing. It's part of maximizing thermal mass, and it gives a better thermal path too.
For a pill that takes a 17mm driver, there's not much reason to leave a lot of empty space.
It'd be different if it was for a 20mm driver since more room would be necessary if a 17mm board was installed behind a 20mm contact board, and even more if chips were stacked. This is a concern with the pills for F13 & F15 I want copper pills for...ideally the pills would be changed to have a thicker top and driver walls with a 17mm driver hole.
Make the depression for the star 1mm bigger then its intended star, the last thing anyone wants is a star that is a tight fit and doesn’t seat correctly, relic38’s convoy m1 had this problem and was causing major heat sag issues.
Also, Bort would like copper pills, but as you can see he cannot afford one
The tallest I'd use in a 17mm pill would be a nanjg105 with double stacked 7135's inside the pill, a thin copper heat spreader, a little potting and 18AWG silicone wire. It's hard to say how much depth is needed for that, but I think it'd be safe if the deck were twice as thick. The depth could be refined if you make more in the future.
