if you want, I still have a Half pack of AAAs. ( 4AAA in total)
Please PM for details.
@ iron potato: thanks for the interest I knew you want some! ;)
Once they are available, I will update the thread, or you can just ask.
If you want them once they are released, is no problem, but I have to charge a bit more, because of local prices.
@ Wings400: thanks for the interest. These are beautiful, but difficult to get as well. They are still available at different shops, unfortunately they are also more expensive, at around $38-$40 shipped.. no kidding!
ChibiM - thanks for the batteries! I’ll take 4 more AA 8 packs and 1 AAA pack. That should do it for me for now.
Just picked up the Maha C9000 charger to go with these. For anyone who is getting one (which you should if you are going to spend the $ on top of the line eneloops), I will save you a few hours of research on how to use it with these Eneloops:
1. AAs: Put 4 batteries in, run a discharge cycle at 400 mA (best discharge rate approx 20% of capacity). Takes about 16 hours, but will say “done” when finished.
2. Unplug Maha or remover batteries for at least 1.5 hours to let the batteries rest.
3. Select and run a “Break in” cycle mode. Default value on the Maha comes up as 2500 mA as the selected capacity. Drop it down to 2000 mA which is the capacity of these AA Eneloops. Repeat selection for all 4 slots. Takes about 39 hours (I just let it sit for 2 days - doesn’t need to be exact. If you drop them in Monday morning, just take them out Wednesday morning).
4. They are ready to use! Suggestion: with a permanent marker write the date you first charged them and the capacity they charged to after the break in cycle (“Nov 2013, 2053 mA” for example). That will help you keep track of them over time. At a minimum it’s a good idea to keep track of the date. Also good to match multiple batteries of about the same charge in applications requiring multiple batteries. The white packaging of the eneloops is ideal to write on.
5. For charges after the initial break-in, charge at 1000 mA. Charge rate should be approx 50% of capacity.
6. Best practice is to run the discharge + break in cycle every 30 uses. The more practical/easier way to do it is to just run a discharge + break in whenever a battery doesn’t charge to more than 1900 mA on any charge.
Repeat for 2000+ uses! If anyone ever gets there without losing your battery first, you should be on a commercial like the million mile volkswagon guys.
For AAAs its the same process, but select 200 mA for the discharge rate (20% would be 160 but 200 is the closest option so you round up), 800 for the break-in capacity of the battery, and 400 for the charge rate.
