. . . large current increase may not be possible without changing drive FET or add another FET parallel.
This is a huge. Many of us have run across drivers we can't realized the desired level of current when even shorting the resister bank. Heat may be an issue, but at least the parallel FET would be sharing the current load .
Finding a compatible FET may be a challenge. Many have the identification labeling ground off by the manufacture. I guess one could find a compatible FET by measuring the physical size of the driver's FET and the voltage differential across the voltage sense resister bank. Do you have any FET recommendations that would likely work in most drivers. It seems that most are the same physical size (whatever size that is) and use a sense current somewhere in the range of .2 to .3 volts.
Thanks Moderator007. Sounds like a promising candidate. One of the SRK driver variants out there uses N channel FETs too. So maybe that FET is similar to what is used in most drivers.
Speaking of FET's. The ones in the first picture of the OP were poorly seated. Probably connected good enough though.
Looking at a SRK driver (version with a large capacitor and one inductor coil). It has two N channel FET's, but I can't tell if they are wired parallel. My labels are ground off, but GTamazing has one too and his is labeled as follows:
DTU
06N03
DD13U
I think the one I have reads over 6 amps at the tail.
Well, I'm not having much luck finding .68 ohm or .82 ohm 0805 resistors around here. I even tried ebay us sellers. Nothing unless I want to go to a kit for big bucks. I don't have anything at home except for a couple R200 here, which won't help and I don't even know for sure if it will do what I want. I'm about to just use five of the NANJG drivers and call it a day, with a shortened tube and one of the Sony 50amp 26650 batteries. 15+ amps, that ought to fry eggs in a few seconds, in that light.
I just don't want to order from China. I've got a hundred bucks worth of orders already aiming for 45 days from, several sellers and nothing can be tracked and none of them want to refund, so I will have to go the paypal route soon, so no more orders from China.
Right now you are at .34ohms resistance. If that gets you to 2 amps, the voltage differential is about .68. So adding a R200 will get your resistance down to .126 and your current to the emitters up to 5.4 amps.
Do you know the size of your R200 resistors? If they are 0805's, they can only handle 1/10th of a watt and would not probably be able to be used in place of the other resistors.
EDIT: If you want to be safer, you can first remove the 2 R820's. Then you would be at about .18 ohms resistance and 3.75 amps current. The best way for me to remove a resistor is to use a blob of solder that touches both ends of the resister. It usually lifts off with the soldering iron.
I can't tell without measuring, but the 3 resistors share the current. So each gets 1/3 of the total current going through them. They should be bigger because 1.36 watts (.68 volts x 2 amps) is going through that bank (if driver is delivering 2 amps stock).
That is an electrical junction box cover. I love to use things for other than what they were intended.
I find that commodity items are cheap and sometimes offer a cheap and convenient solution to construction projects.
I would have to wonder how much added resistance all that wiring adds to your circuit. You may not be getting an accurate picture of what the draw would really be. If you are only interested in a before and after comparison then maybe it wouldn’t matter so much.
with 3 batteries = 3.7v x 3 x 2A = 22.2W
with 2 batteries = 3.7v x 2 x 3.75A = 27.75W
that mean higher the input voltage, higher efficiency.
Now LED current confirmed 1.5A so
voltage drop in sense resistors 0.34 ohm x 1.5A = 0.51v
on this bench test, you can solder regular resistors and check LED current improvement.
for 2.5A you need 0.51 ohm, for 3A its 0.33 ohms.
I would not bank on 1.5 amps to the emitter. Dchomak had a good point about all the wire and connections in the rig pictured above. It's quite possible that the driver will deliver the rated 2 amps in the light. Especially with O-L's skill at lowering resistance in a light.
Didn't realize that. Thank you for that info. In Post 26 above, don't you mean he needs about .2 ohms overall resistance to get 2.5 amps and .17 ohms for 3 amps? Resistance is already at .34 ohms.
