Paid for 2 hd2010.
Can you please make sure I get deeper pills that I can stack chips onto?
Cheers,
Chris
Paid for 2 hd2010.
Cheers,
Chris
Got it, thanks. Added you to the list.
Not sure if my post on the last page was missed, can you confirm you have received PP payment. Also add me to the list for the deeper pill for stacking, thanks.
Whoops, sorry about that. Got your payment and form and added you to the list.
My thinking on the o-ring, yes, I've seen it there and not there... I don't think it's a good thing having it there - the pill thread/contact is for electrical path and thermal path, so, an o-ring serves no purpose being there. It makes the connection feel tighter, but can't see how it may help the metal to metal bonding on the threads. From the pic, looks like vob left space for it and still got 6 threads.
Dunno - I wouldn't go crazy at this point. Your call to weigh the risk/delay/advantage, etc.
Thanks for that, I’ve just returned from the shop and unfortunately the machinist said that he wouldn’t be able to increase the number of threads because it was too close to the top. Sorry about that guys, but I think we’ll have to go with 5 threads for now.
Some changes I made today:
-Ensured that when the HD2010 bezel is tightened down, the stock 16mm PCB has a snug fit and the 20mm copper Noctigon has a solid fit.
-Allocated 25 HD2010 pills for the extended driver space and 15 HD2010 pills for the regular profile (stock 8x AMC7135 and East-92) drivers.
-The PCB contact area will have a nice smooth finish for both pills.
We’re initiated production, will update you guys on further progress.
Thanks!
Hi Ryan, I’ve already ordered and paid. I need the deeper pill please. Thanks for the effort on this!
Added, thanks!
Payment sent for 1 x HD2010 Cu heatsink
Thanks again!
Nice work Ryan, you’re really staying on top of this…Well Done!
PP and form received, thanks!
My college apps are all done so it’s only a matter of time now.
Cheers guys!
I’m sure others will probably do the same but I’ll definitely be doing a before and after extended run (temp/output(lux) comparison on my 6A nanjg HD2010 (draws 5.84A on a fresh Kinoko IMR 18650). I’m keen to see what real world difference the copper pill actually makes in this host.
I’d like to see not only what run time difference it makes, but how it affects output during that time. The emitter will obviously be staying cooler, longer, so what would the out-the-front numbers look like while the run time test was being conducted? I don’t have measuring equipment to conduct this kind of test or I’d be all up into it my own self!
Maybe you posted bout this light mod, dunno, if so, do you have a link? Didn't think 5.84A on a stacked up Nanjg was possible in a single cell, at least for a high Vf demand setup with an XM-L2/copper. Copper pill should benefit this setup. I got my vob copper pill measured at 5A using a Powerizer 26650 or SONY 26650. Don't have Kiniko IMR's though - are they less internal resistance than a Samsung 20R?
Edit - ohh, the HKJ review indicates it's the same as a Pana CH. I can't get near 5A, yet alone 6A with a cell that high in resistance (0.08 vs 0.04 for a 20R) - in this thread: https://budgetlightforum.com/t/-/21733, you mention a HD2010 with an XML U2-1C, if so, then yes - can be done...
Like I said, I’m getting 5.3A on a stock unmodded HD2010 with a FourSevens Protected 26650. I haven’t been able to find a single review on this cell. I wonder who the manufactures this cell is.
On the stock East-092 driver with the stock XML/alum, I can see that - yes. Still for a protected cell, that's good. If it's 4000 mAh rated, it may be a KK cell so already has a good low resistance foundation, then if the protection circuit is well designed, you are good there. KP will OEM also, so the FourSevens could just be a KP under their own label.
Yes sorry I should have been more clear. It’s an original XML U2 on copper from led-tech. I have yet to step into doing single cell high output stuff with an XML2 so I wouldn’t know as well as you what’s doable with those emitters.
I’ll also say that I only get this high a sustained current on those kinoko IMR cells, my Trustfire 26650 5000mahs max out at about 5.4 for one and 5.15 for the other older one. They also drop faster from there.
I’m also still using the stock very thin emitter cables that came with the HD2010 so I could probably get closer to the total potential those 16x7135s if I upgraded there. 6A sounds very doable especially on those Samsung 20R
I tested two new fully charged unprotected KK ICR26650 against two Protected FourSevens 26650, and the unprotected KK couldn’t get past 4.9A.
Ohhh - wow, that's an incredible protected cell then. Forgot, I posted this in the other HD2010 copper pill thread:
The 4.9A Nanjg is in the HD 2010 pill now. For the bare pill with a de-domed XM-L2 U2 1A/Noctigon, I measured 5.0A on each of the 2 Powerizers -- not bad. The SONY 50A got 4.95A, MOLI got 4.60A. On a stock HD2010 with the East-092 driver:
SONY 50A 5.6A
Powerizer #1 5.4A
Powerizer #2 5.4A
MOLI 5.3A
Samsung 20R 5.1A
KK ICR 4000 4.7A
KK ICR 4200 4.6A
KK INR 4000 4.55A
The KK's and 20R are the oldest and most used, while the others are newer. All are pretty much fresh, maybe charged in the last week or 2.
I see posts of the good stock hd 2010 having 5amps… Is this okay on aluminum or should some measures be taken?
