Wow I’ve read so many posts talking about stacking, but to see a pic of it…
That’s crazy-neat. Thanks for the info!
Woah.
I tried a 5 stack and it was a complete fail.
That looks like awesome ‘fun’!
Chris
If you’re going to build tall, running a strand of coppper braid vertically for “reinforcement” is essential. Bridging the gap between the pins is much easier that way.
At least that’s the only way I could pull it off, there’s members here who have been stacking for way longer and probably have some better tips
I just use both sides of the board, stack one on top of all 8 on the Qlite driver for a theoretical 6.08A. Just got through doing this with the MT-G2 in my M8 moments ago, with Samsung 20R cells it’s pulling 5.65A at the tail, didn’t even check to see if the cells are topped off. They should be close if they’re not.
That’s some 3000 lumens on Hi, around 1000 on Med, and 400 on Lo. Approximately.
There was a pic of i think a german guy who has stacked like a gazillion high?
The FourSevens 26650 cells are 68mm protected flattops.
How many AMC’s can be stacked into this C8 pill ?
I’m considering 12.
Is there suffice space ?
The original pill can fit an extra layer of AMC7135 chips on the top, so you could have 12 chips in total.
The 3x AMC7135 edition pill can accomodate two extra layers of AMC7135 chips, which allows 16 chips in total.
Here’s some progress that we have made: Eyecandy alert
WOW!
I'm seeing the appeal of copper. :D
xd…
How many are left for sale?
Currently 23 HD2010 and 14 Convoy C8 left.
And unbelievably fast!!! Man, seeing those makes me want to buy more, worry about getting lights for em later! lol
Your camera flash is making some of those beauties look almost like aluminium! This is simply unacceptable!
Seriously, you need to put a filter in front of your flash so they’ll look like Gold instead.
I don’t believe I used the flash, with my Nexus 4, the copper pills were washed out when I used it.
It’s only the lights on the ceiling.
Did a quick tweak on one of the pictures, mostly white balance...
There are many things that can be said about copper pills. But I think everyone feels the urge to give one of those puppies a new home.. ;)
They sure look good! :love:
I also downloaded that pic, opened it up in Photoshop and tried to make those two baskets of copper appear on my desk, didn’t work. Maybe On1 or Topaz will get it. I’ll keep trying, but might wait til they’re threaded and drilled
4.9A, double stack on the side:
4.9A, double stack on the back:
Might try 5.6A on for this copper pill, but only cell that might have a chance is a Powerizer...
Thanks for the photo edit RaceR, looks much better.
Great stacking skills. I’m assuming the chips can’t be stacked on the battery side of the driver due to space constraints?
Thanks!
