I just use both sides of the board, stack one on top of all 8 on the Qlite driver for a theoretical 6.08A. Just got through doing this with the MT-G2 in my M8 moments ago, with Samsung 20R cells it’s pulling 5.65A at the tail, didn’t even check to see if the cells are topped off. They should be close if they’re not.
That’s some 3000 lumens on Hi, around 1000 on Med, and 400 on Lo. Approximately.
I also downloaded that pic, opened it up in Photoshop and tried to make those two baskets of copper appear on my desk, didn’t work. Maybe On1 or Topaz will get it. I’ll keep trying, but might wait til they’re threaded and drilled
PP sent as friend with standard tip for one copper C8 pill.
I plan to direct drive a Phatlight Pt-54 red led in it, which I heard from some that it draws 6A and others that it draws 13A. I’ll have to get an Omten switch from FT and better springs from saabluster.
I really like how the SolarForce M3 head looks compared to a C8, but the M3 reflector that the pill threads into isn’t itself threaded into the bezel.
I’m still in the market of buying 3 copper P60 pills though.
