100% correct. Good luck and let us know how it turns out ;)
I intend to do a full write up of when I put the Convoy L2 thrower project together. All this is making me look forward to getting back home, along with messages from my sister that my packages are arriving back in Oz (including the Vinh modded BTU shocker)!!!
My order with the LD-29 drivers never made it out of Hong Kong. I should have ordered the batteries separately.
I have moded two of the ld-29 first one with 5% 0.02 ohm resistor and measured the current at 3.2Amp to the XML2 instead of theoretical 3.5 amp. The second one received a 1% 0.017 and delivered only 3.7 amp but no calculated 4.1Amp.
Is that with one battery or two and what cells?
That was with two 18650. Current draw from the batteries is about 2.2. Didn’t calculate efficiency coz I didn’t measure the wilt age across the led or the batteries. I can do it if you need it.
Ok did the measurements. Ld-29 modded with 1% 0.017 ohm resistor delivers 3.67 amps to an XPG2 at 3.63 volts that is mounted on a 20mm sinkpad for total of 13.36 watts while drawing 2.25amps from 2s 18650 with voltage under that load of 7.3 volts for total power draw of 16.425 watts. So the efficacy at that drive current is about 81% and loss about 3 watts in the driver. Not bad but could be better.
Thanks for trying. Thats a nice little bump in output, especially for those that already own this driver and are able to mod.
Thanks Blue. If my drivers ever come I’m going to try the same. They should have been here but I had batteries on the same order and it got sent back.
Just eyeballing that it looks like each one is 10% less than expected. Maybe I’ll calculate the resistor needed for 10% more current than I want and hope for the best.
Just tested the driver with two 0.025 resistors stacked for 0.0125 ohms and got about 4.8amps and slowly dropping down to 4.55 amps over about a minute. Driver got extremely hot, the inductor the most.
Edit: did some more measurements and calculations. Total power lost in driver at the 4.6 amp current is almost 4.5watts!!!
Draw from two 18650’s is 3Amps at 7.15 volts for total of 21.35 watts.
Led is 4.6Amps at 3,67 volts for 16.88 watts. Total loss in driver is 4.47 watts. Can you say hot driver?
That’s about 80% efficiency. Sounds pretty normal, but time to get the potting compound out.
I want to get 3.8A on LED.
As I understood, I should remove native resistor 0.025 and install 0.018.
(R = V/I = 0.07/3.8=0.018)
Is my calculations correct?
For buck and boost drivers, efficiency, usually, is more or less inversely proportional to input/output voltage delta (difference), so you can manage more power in the driver if you can keep this voltage delta minimized.
I’m currently planning on soldering 0’05Ω in parallel with the 0’025Ω nominal one, for a theoretical current delivery of 4’2A if we do not take into account battery contacts, cables, springs and other resistances into the equation.
Should deliver around 3’7A at 6’25V to an XHP50.
Cheers
I thought the ld-29 was intended for 3v emitters. How do you plan to get 6.25v?
No. The LD-29 is a buck driver, which means it is a current controlled switching power supply. It uses a logic IC which monitors voltage drop across a shunt resistor (0’07V in this case). That means:
- If the measured Vdrop is above reference (0’07V), too much current is flowing; output voltage is adjusted proportionally downwards (theoretically multiplied by the quotient between reference voltage and the measured one at the shunt’s terminals).
- If the measured Vdrop is below reference (0’07V), too little current flows; output voltage is adjusted proportionally upwards (again, theoretically multiplied by the quotient between reference voltage and the measured one at the shunt’s terminals).
Quintessentially: the ratio between the reference voltage and the measured one at the shunt’s terminals determines the figure you need to multiply the voltage output with, to reach the desired current flow ratio.
With 2 li-ions in series, you’re guaranteed to have at least equal or above led voltage output at the input, even for a 6ish voltage drop led.
Hope this helps.
Cheers :sunglasses:
Thanks Barkuti, that might be the best explanation Ive read describing the operation of a buck driver.
But not all buck controllers will do higher than ~4v output, no matter the input voltage. The LD-29 used to have that limitation. Have recent versions been changed?
I suspect this limitation would be present in the older version used in the L5. Can anyone confirm?
