I received the prototype board today, Thanks PilotPTK. I am hoping to have the housing done next week. I am still finalizing the design.
I added a power input on this one for the motorcycle guys. It now has dual power inputs like a regular headlight low/high. One input for low the other for high.
The optic that is pictured is the flood. The spot is clear.
Will the round lights be side mounted or bottom mounted? I'm trying to think of how I'd mount them on my motorcycle, ideally as a headlight replacement.
I'd almost certainly run two of those to fill out the front. Or just the 6x lightbar if wiring is still simple.
Finished turning the body tonight. Came out really nice. My butthole was fully puckered and I had my finger hovering the feed hold while machining the grooves. The deep ones are .875” deep x .120” wide.
In a way he might be asking if the mounting holes on the light are at the center of gravity. If it's not, then vibrations may eventually cause it to point up or down. At least that's what I wanted to know.
