It’s just another variant of the new wave of 4P 18650 soupcan light. The SRK has never held any appeal for me personally. This light looks to have better thermal management capabilities than an SRK.
…but, I haven’t received mine yet and torn it down.
My Nage triple gave me 3.45 emitter amps. from each of the three 9 chip banks.
My final tail reading with all three emitters on high is 8.55A. I hope the switch holds out OK.
I wonder if you could do a Zener diode mod with this driver?
This looks awesome; it might have to be my first triple emitter.
I’m wondering if the deep polished bezel ring might leave an outer halo
Great, this might be just the light I’m looking for. Thanks for the info, guys.
The 8.55A tail /3 is 2.85A per LED, but, maybe it's drawing 4.2v or so, but providing 3.5v or so per LED, that's why the actual LED amps is higher at 3.45A?
9 chips per LED, if they are 380's, is 3.42A at best, for 350's, it's 3.15A per LED. Usually 380's read low and 350's read high. Of course there are loss's along the way.
The 3.45A readings were correct. Each sector was tested separately with the driver removed from the body and hooked up to a heat sinked XML using two fresh cells in parallel. I took readings as each chip was added to make sure it was working.
The series mode (1-2-3-1-2-3-1-2-3)at the tail shows 4.45A-4.46A-4.44A proving that each emitter is putting out that current individually.
I think when all three emitters are running on high at the same time, the law of diminishing returns comes into effect with a return of 8.55A.
I spoke too soon. The switch is on the way out. It started with a lag of a second or two before the light came on, then it wouldn’t come on at all. Sometimes if I set it down, it would eventually come on minutes later. I jumped the switch with a DMM lead, and it comes on no problem. I know that switch is rated for 1.5A.
Gotta look for a new switch.
Many/some push 10-15A+ through these:
http://www.fasttech.com/products/1009/10001865/1135000
http://intl-outdoor.com/omten-reverse-clicky-switch-pbs101-5-pcs-p-566.html
Looks similar, also rated 1,5A. But they seem to get the job done.. :)
Rats. I just placed an order with Hank yesterday.
I saw the way you have blowing switches up lately and was going to PM you.
Genuine Omten 1.5A clickies like those from fasttech/IO will handle 15A no problem and do it reliably and with low resistance loses in my experience.
There’s loads of variations/copies out there though and from what I’ve seen most are no where as good as the real thing. Most of the noname ones that came in my C8s have been crap, lose solid contact pretty quickly and have a mushier action than the real ones. Omtens have quite a stiff spring and solid action which I’m sure helps them function well at high currents but they can feel a little less refined sometimes.
You can try a small amount of PTFE based spray lubricant applied around the clicker switch. Once it dries it can smooth out the action a bit but be warned I don’t know what this does to the reliability of the internal contact surfaces long term.
Yupp, in general Omten seems to be very good.... :)
Btw Ouchy, you assume the driver in your nage and this "yupard" are similar. But the Nage uses mechanical switch and this one uses electronic so they cant be 100% similar...
By the way, I also ordered the “YUPARD” 5x CREE XM-L T6 LED 6000 Lm LED Flashlight Torch Spotlight Searchlight . I don’t yet know what I’m going to do with it, but it’s going to be a long winter. It seems to be a clone of the Solarstorm Raging
It looks like the driver is not the same one as in the Solarstorm. Great price though.
That is a good price for that type of light. Thanks for sharing. :)
No, not the same. That was just off topic chatter with Tom E about my last mod with the same driver.
Awesome, glad I threw a pair of those in my last FT order for my mag build (only shooting for 3-5 amps though).
Maybe post an ad for the spare OMTEN you get with a Trustfire x6?
Boy, I'd love to get my ordered one in before ordering a 2nd though, just to be sure...
Tom! That driver has your name all over it.
