All batteries are available again.
The so to called buyer (a well known seller) never replied to me, even after 5 days and 3messages.
So they are available again.
Hi, I will take two of the AA 8 packs and one of the AAA 8 packs. Ships to California, USA.
Thanks!
Hi, I will take 1 pack of the 8x AA classic thanks, to South Africa.
Hi Flitsmal, thanks, they will be yours!
And jonorjt, yours are sent out yesterday.
Currently 4 AA packs left.
added to the bunch..probably only limited sales...
4 packs 4* Eneloop AA PRO latest gen. BK-3HCC.............$19 per pack, or $20 including airmail
Just got a few more.. some are on Hold, but I didnt include those in the new available batteries anyway.
If the potential buyers back out, I will add them back to the amounts in the OP.
See for current availability the OP
2 packs 4* Eneloop AA PRO latest gen. BK-3HCC………….$19 per pack, or $20 including airmail.
PM sent
ChibiM - thanks for the batteries! I’ll take 4 more AA 8 packs and 1 AAA pack. That should do it for me for now.
Just picked up the Maha C9000 charger to go with these. For anyone who is getting one (which you should if you are going to spend the $ on top of the line eneloops), I will save you a few hours of research on how to use it with these Eneloops:
1. AAs: Put 4 batteries in, run a discharge cycle at 400 mA (best discharge rate approx 20% of capacity). Takes about 16 hours, but will say “done” when finished.
2. Unplug Maha or remover batteries for at least 1.5 hours to let the batteries rest.
3. Select and run a “Break in” cycle mode. Default value on the Maha comes up as 2500 mA as the selected capacity. Drop it down to 2000 mA which is the capacity of these AA Eneloops. Repeat selection for all 4 slots. Takes about 39 hours (I just let it sit for 2 days - doesn’t need to be exact. If you drop them in Monday morning, just take them out Wednesday morning).
4. They are ready to use! Suggestion: with a permanent marker write the date you first charged them and the capacity they charged to after the break in cycle (“Nov 2013, 2053 mA” for example). That will help you keep track of them over time. At a minimum it’s a good idea to keep track of the date. Also good to match multiple batteries of about the same charge in applications requiring multiple batteries. The white packaging of the eneloops is ideal to write on.
5. For charges after the initial break-in, charge at 1000 mA. Charge rate should be approx 50% of capacity.
6. Best practice is to run the discharge + break in cycle every 30 uses. The more practical/easier way to do it is to just run a discharge + break in whenever a battery doesn’t charge to more than 1900 mA on any charge.
Repeat for 2000+ uses! If anyone ever gets there without losing your battery first, you should be on a commercial like the million mile volkswagon guys.
For AAAs its the same process, but select 200 mA for the discharge rate (20% would be 160 but 200 is the closest option so you round up), 800 for the break-in capacity of the battery, and 400 for the charge rate.
Cheers!
Troisanh, 2 pro packs for you.
Jonorjt, 4times 8*AA and 1 time 8*AAA.
Thanks for the informative post!!! Thanks for sharing.
Everything SPF again.
Hahaha… I already lost 3 of the little buggars and the headlamp they were in. No more letting family borrow anything I have eneloops in.
Newest Glamour eneloops are available as of today, November 29..
They are still a few $ more than regular eneloops, but that`s usual for ltd editions.
At least they have come down quite a bit upon release, so that I can sell them for $32 per pack, including shipping.
If somebody is interested in getting a pack, please let me know..
Hi ChibiM,
I am interested in 3 packs please.
Thanks
Hi Flitsmal,
Okay, I will go and buy a few packs.
I will let you know when I have them!
Cool…
Like that pink…. :heart_eyes:
I’ll also take 2 of the 4 packs of enloop pros when you get them.
Thanks!
Updated with new stock..
2 PROs on hold for FMCamaro
New available:
Got 3 packs of AAA, so updated the OP
hi, Chibi, is there any chance of getting eneloop pro WITHOUT panasonic name on them? nothing wrong with panasonic but i am so used to name Sanyo eneloop that it’s now very hard to switch…i guess this sounds somewhat awkward…i just hope i’m not he only one feeling this way…
Hey Kralyevski,
they are still available, but at a higher price. And definitely most shops don`t have them anymore. Some shops do, and like other (special editions) they tend to keep the prices high.
Honestly, the panasonics arent bad ;) you`ll get used to it very quickly.....(maybe)
And the following few packs are having a little rest before they start traveling the world.......to South Africa
All Eneloop PRO are SPF
i would like some AA uomo if you can get them
