ryansoh3
(ryansoh3)
November 23, 2013, 5:04pm
199
Side by side, barely, but without both to compare with, not at all.
sb56637
November 23, 2013, 5:38pm
200
Hmm, my only reservation about buying the Xintd X3 is that the reviews mention that it doesnāt work with protected Li-Ions because of the longer length of the cells. I strongly prefer protected cells, so thatās kind of a downside.
RaceR86
(RaceR86)
November 23, 2013, 6:48pm
201
3,04A-2,80A=0,24A extra.
In real life the difference is more like 0,15A extra based on what I have seen. (due to 350mA 7135s usually overperform, and the 380mA sometimes underperform. Qlite might also have a tad of PWM on high)
0,15A difference is close to nothing.. Its about 5% more current. Which probably is no more than 4% more light on high..
Thanks for the coupon code _the_.. Tempting, tempting... Im not supposed to buy this light...
Sirius9
(Sirius9)
November 23, 2013, 7:26pm
202
fyesilova
(fyesilova)
November 23, 2013, 9:03pm
203
I have ordered the extendable baton, it is irresistible price.
I am not happy with SK68 clones I have received from BG. May be this time they will do good.
veer
(vÄer)
November 24, 2013, 11:13am
204
Regarding those X3 tints, can anyone give me a short description which tint is what?!
T4-7A
T5-5B
T6-3B
T6-4C
U2-1A
I figured I'd make a guide related to XM-Ls and tint, binning, CRI, and all the other details I can think of.
Tint
There are 3 basic tints.
Cool White is a very pure white and is what most lights are. This generally has a low CRI (color rendition index) and will not show colors that well. Some people say that it is to blue. It is generally around 6000k.
Neutral White is considered to be one of the better tints as it still seems fairly white, but does have a higher CRI. It ā¦
I found this pretty informative.
p_k
(p_k)
November 24, 2013, 12:35pm
206
Agreed, thereās another āANSI-chartā here, a bit easier to read the text. File:Ansi-white.jpg - Flashlight Wiki
EDIT: Hotlink removed, thanks the
_the
(_the_)
November 24, 2013, 11:44am
207
That's what I always use. However, flashlightwiki doesn't like hotlinking, so here's a link to the page: http://flashlightwiki.com/File:Ansi-white.jpg
sb56637
November 24, 2013, 12:47pm
208
For a description of those tints, basically, this is what I have found:
7A = very warm
5B = neutral, tending towards yellow
3B = neutral, tending towards cool
4C = neutral, tending towards red (this one is described as very pleasant by many)
3C = standard āneutralā tint (not available for the Xintd for some reason, but probably the most common tint described as āneutralā)
1A = standard ācoolā tint (by far the most common tint on most flashlights)
This post was also helpful: What LED tint do you prefer?
In my experience 5B can often be redder than a 4C. 5B is certainly warmer, but the balance between red and yellow in each can vary.
OscarM
(OscarM)
November 24, 2013, 1:52pm
210
can klarus p2a/p1a be opened up easily for upgrading the led?
Sirius9
(Sirius9)
November 24, 2013, 2:23pm
211
I highly doubt they canā¦
Essexman
(Essexman)
November 24, 2013, 2:55pm
212
New stainless smooth 18650 light on new arrivals.
So the question is, what has been photoshopped out on the photos ??
veer
(vÄer)
November 24, 2013, 8:33pm
213
Thanks, guys, for both the detailed and simplified explanations :)!
ChibiM
(ChibiM)
November 24, 2013, 11:49pm
214
I've tried it several times to open,p2a, but without success.. I should probably use much more heat, but am afraid to damage it.
Werner
(Werner)
November 27, 2013, 1:14am
215
They now have dqg lights, maybe you could make a deal with themā¦
They also have now the handle light which was discussed in the wallbuys thread for a while
SantaClaw
(SantaClaw)
November 27, 2013, 3:52am
216
So I ordered myself a XINTD X3 CREE XM-L2 3/5Modes 2Groups 1000lm LED Flashlight with a T4-7A LED and protected 26650 5000mah ultrafire battery
Flashlight
Just hope there is room for a protected cellā¦
SantaClaw
(SantaClaw)
November 27, 2013, 4:47am
218
