Also if I stuck a 10k variable resistor as the current resistor could I then install one of those cheap led ammeters for checking the current or would that being there mess with the charging?
Hello. Does anybody know if it exists a module like this, but for charging LiIon in 2S configuration? Or should I use one of these cc/cv modules adjusted to 8.4v and one of these FT protected battery boxes ?
Nice mod crx.
Changing the current resistor isn’t hard if you reflow the board on a hotplate or stove. You can keep a eye on the temp with an inexpensive food thermometer. 0805 resistors fit ok on the pads. Needs just a tiny bit of solder paste.
FT 0805 3.9K-62K Resistor Pack
I aim for as low as will flow my solder. Sn63 Pb37 should flow around 183°C.
Probably better to keep lead solder out of your kitchen if possible. People use a portable electric hot plate / stove or griddle. If you have any, a piece of scrap metal is usable instead of an old pot or pan. Could even try a flatened piece of a soda can aluminum if nothing else is available. Not sure if the heat on such thin aluminum might be uneven on a gas or coil electric burner. Worked ok on a flat top electric burner.
~ edit ~
Guess you don’t really need solder paste at all for this. You could pre-tin the new smd resistor with any solder. Then reflow the board, remove original resistor & place the new resistor while its hot with tweezers.
Original tp4056 NanJing Top Power chip. Datasheet
The chip that HKJ tested. Also pictures that others posted have all shown this chip.
I’ve bought from Chip_Partner and ICs_Processors for $1.54. Always received original tp4056 Top Power chips. RMM now has them for $1.42. Once brought a cheaper board elsewhere & got an unmarked chip. Was not cc/cv at all. I did get a refund tho.
I didnt re-read the whole thread, so excuse me if this has been adressed already :D!
The question is - should the battery be connected to charger prior to plugging charger into electricity or not?
Im asking this because in both of of my TP4056 boards if I instert battery after they have been plugged into electricity then it will show it as fully charged(red led on) even though the battery is well below 4.20V.
When I put multimeters probes to test voltage then the blue LED will light up indicating that it has started charging the battery.
When I connect battery first and only then plug chargers into electricity, then it will seem to charge fine, however, not always, at least on one of the boards it might as well display battery as charged even after multiple attempts unplugging and plugging back into electricity outlet.
I suspect that Ive messed them up during soldering+accidental polarity swap while checking magnets might have ruined them :D!
It is good policy to power up the charger before attaching a battery to it. This is a must for my iCharger to avoid damaging the charger (according to an email from the German representative of the iCharger where he warns against the risk). Therefore I also do that with my TP4056 charger.
Likewise, the battery should be removed before turning off the charger.
Those boards aren’t actually much larger, just longer & a bit narrower.
But I can’t see the TP logo on that one. Doesn’t look like the original tp4056 NanJing Top Power chip that HKJ tested. See post #43.
Instead the markings look like they might be 4056ES A1319N. Some kind of symbol or logo seems to be before A1319N. It could be yet another clone chip. Unless you can test it and chart its charge profile I would just stick to the original chip (stylized TP logo) that HKJ tested.
The datasheet for the NanJing Top Power chip claims a max input voltage of 8 volts so 6v should be fine.
Just connect positive from the solar panel to IN+ (next to the usb jack) on the tp4065 board, solar panel negative to IN-. Do not use the usb jack if the solar panel is connected. You could use a couple 6V300ma solar panels to charge faster. Check with a multimeter that the solar panel are actually providing enough voltage & current.
Has more components in addition to the 4056 chip, and costs a bit more. Wondering what the diiference is.
The board cuts the power at 5.5V but I don’t know what that solar panel delivers. Wonder if I could cover part of the board , if V too high, or does that cut A?
At 5.5V the tp4056 board did reduce charging current in HKJ’s tests but that was a tp4056 board being supplied with 5.5V @ more current then your 300mA solar panel. Probably over 1000mA.
At lower currents it shouldn’t heat up as much (it gets rid of extra voltage as heat) & shouldn’t need to reduce its charge current.
The 2 extra components are just jumpers. Marked “R1” and “R5” in white text on the board. Marked “0” on the components. They are jumpers / zero ohm resistors.
There is one thing this board does provide that the other one doesn’t. It has a point to connect to the TEMP pin. Requires extra components to actually use that though. NTC thermistor & a proper resistor to set the temperature cut off.
Thank you for the all the information. Would be interesting to set one up to shut off at a certain temperature.
Thought about it, It makes a lot more sense to start out with a couple solar panels and see how it goes. I might start with 2, if I get 250 ma or more, maybe just connect one. If I get less than that, maybe 2 in parallel to double it. I could leave it outside, I suppose, as long as I shaded the board & battery.
How much amperage could I run through this? Saw 1200 ma in the data sheet, although it might be hard to keep cool at that, especially over 5 V.
Actually when I reflow mine (I have a hotair rework station) I just snag the old RProg resistor off with a pair of needle nose tweezers, then lay the replacement resistor on the pads, there is enough residual solder for it to stick and bond no problem.
Also gotta be careful with some of the square TP4056 boards [longer rectangle ones seems 0805 standard], the RProg resistor is a 0603, the 0805’s will fit but you have to be a bit more careful on placement
This is the board I changed for fellow board member woolfam, not the most beautiful solder job, but I tested and they too were pushing a clean .53A and .48A respectively with a 222 resistor on RProg
Changed the 122 [1.2K resistor = 1A] to a 222 [2.2K resistor = 500mA~] Tested, was pushing .53A to a 3.6vdc battery out of the USB module into a repaired Xtar MC1 slider housing
I can confirm at 1A charge the TP4056 gets VERY hot, burned my finger when I put it on it to see how it was doing, at 500mA…warm but not leave a mark on my finger.
