I’ll be stripping the driver board eventually to go for a linear driver setup, so I’m happy to try and toast it and the emitter by doing some resistor mods first.
:beer:
So far I have not modded lights but I’m eager to try my hand at it. At the same time I don’t want to mess up any good ones so to speak. This light has really appealed to me and from the sounds of it has lots of potential. Given some of its challenges would this be considered a good canidate for a first time or should I stick with something more mainstream like a C8 or something?
Convoy C8 host would be a good first 'Flashlights For Dummies' project, lol. There are tricks to learn even for a build that uses all off-the-shelf parts, it will serve you well to start with something rather more difficult to screw up. :)
... just ordered one from KD; I'll put in a linear driver.
Thanks for the tear down Linus.
A C8 is a good modding choice for the first time, very little chance of messing anything up and parts are readily available and don’t have to be made to fit.
The OP reflector is also very forgiving in terms of getting a good focus and alignment, this can be one of the more frustrating parts of modding a throwy light. At least it can be for me and ruin the whole experience if it’s difficult! HD2010 I’m looking at you!
With this light you may have fun doing basic mods… focusing the emitter, upgraded wiring, emitter swap, maybe a resistor mod etc, but to really get the most out of it and drive it hard it needs a bit more custom work. Adding 7135 drivers will also require some special fitting/heatsinking and considerations regarding the electronic switch.
Have a stab at a C8 first and see how you go, then look at this light once you know some of the basic pitfalls of modding
Is it possible to change the switch into mechanical switch and use one of those common Nanjg 105C drivers?
Yes you may be able to do something like this, there’s plenty of room in the driver cavity to mount a decent sized reverse clicky from the inside. Then add some kind of an extension onto the side switch plunger that goes all the way down to it. Or replace it with a small rubber boot and plunger. Probably hard to get it watertight but otherwise I don’t see why it wouldn’t be possible.
I’ve also been thinking of adding some kind of a lockout mechanism to the tailcap. I’m thinking along the lines of a simple contact plate or shunt attached to the tailcap that completes the circuit when the tailcap is screwed on tight, but can be locked out when the tailcap is unscrewed a couple of turns.
A momentary switch that can handle high currrent and can be depressed by the tailcap may also work and be neater…
Even easier would be to just replace the filament wire with a pair of bullet connectors on short wires that can be disconnected if the light is stored for longer periods.
There’d even be room in there for a tailcap clicky switch but you’d have to drill through the cap and install a switchboot to make that work.
Can the battery tube be reversed, so the anodized threads go at the front?
Not directly, the threads are the same on both ends but the tube isn’t completely symetrical. So for example the front of the battery tube has a deeper recess than the rear where they mount the spring pcb. Could probably be made to work with some standoffs though.
Also from what I can tell the front of the battery tube body only makes ground contact to the driver through the threads itself. It doesn’t press up against the grounding ring of the driver board directly as is usually the case in other lights of this setup.
It’s probably why I had the flickering problem at the start.
Poor grounding contact only through those solder blobs on the back of the contact board, relies on combined pressure from the press fit and the batteries to make contact. Another area for improvement
So I don’t think lockout by unscrewing the battery tube a turn or two is going to be a possibility.
Small update:
Was tinkering with the light and taking some tailcap/emitter current readings tonight.
In stock form I was getting a stable 2.58A at the tailcap.
Emitter measurements went as follows.
Meter connected with long thin crocodile wires clipped to the original tiny emitter cables gave me 2.04A at the emitter.
Ditching the crocodile wires and soldering my thick meter leads directly to the thin emitter cables gave me an initial peak of 2.69A but then dropping to 2.58A.
The fact that reducing the wire resistance increased the current indicates that this isn’t a true constant current buck regulator right?
Or do I have that backwards?
Upgrading the emitter wires from stock to 20Awg raised the tailcap reading to 2.9A, I also managed to get a voltage reading of 3.17v across the emitter in this setup (that doesn’t seem right to me, going by the datasheet I should be seeing closer to 3.3v to get near 3A).
That’s the last measurement I took before I accidentally shorted the emitter positive across the reflector and blew something on the driver, at that point I only had a firefly mode high and low. All modes still worked but at severely reduced output…
Looking closely at the driver I noticed the supposed sensing resistor (R200) had a burnt mark in the middle and measuring it’s impedance gave me in the region of 50 Ohm.
Ok so I figured if nothing else had been damaged I could just replace the burnt resistor and might as well do some resistor modding while I’m at it.
So I took some of those smaller R500 resistors I had around and stacked 4 of the buggers to replace the R200. Should give me a total value of 0.125 Ohm.
Tested the light and there was lots of light again, the driver was alive once more
Maybe a bit brighter but hard to tell so I took some more tailcap measurements to check. These are a bit weird and I’m really not sure what’s going on anymore. I now get values that start at 2.8/2.9 and steadily rise to over 3 at the tailcap, max I measured was about 3.4A.
I guess the increase is somewhat consistent with the resistor modding but the rise has me baffled…before the mod it was very stable at 2.58A…
Anyway, I don’t really know what I’m doing with testing these kinds of drivers and this whole thing has left me more confused and disheartened than enlightened. The driver may not be working 100% after the short anyway so I would definitely take my values with whole lot of salt…
In any case I will soon be tearing the components off this board and getting a linear driver in this light instead.
So much easier to understand and control
Cheers
Likely not a buck driver, that would be pretty pointless in a light with a max Vin of 4.2v. Try it with 8.4v and a XML, or 12.6v and a MTG2... doubt you'll get anything but fried parts.
'Constant Current' is a different kind of thing from a buck driver that outputs a constant current. 'Linear' and 'CC' are describing the same thing, somewhere along the line some buck drivers got the incorrect CC label attached to them.
Making it lock out at the front like a SRK is possible, in theory at least. Isolate the driver from the head, add a larger OD contact ring onto the driver's ground ring. That way it doesn't matter if the head is connected to BAT- through the threads at all times, as long as the connection between the battery tube and driver is broken it will be locked out.
Just stopping in to say thanks for the teardown.
Mine should be in my possession tomorrow! My level of knowledge with this stuff is minimal so I will be waiting for proven results and I’ll follow someone else’s mod guidelines for this light rather than experiment
Definitely considering an xpg2 on copper and adjusting the focus to start things off.
It doesn’t have any cooling fins tho. How much amps you think it will take?
Yeah should be possible if you do it like that, although you may run into issues with battery clearance once the contact ring is high enough to press against the battery tube.
I tried adding some tall solder blobs onto the battery side of the contact ring where the little ears are. Just to try and increase the height and make contact with the battery tube edge, but after a certain blob height the batteries started hitting them when screwing on the tube…and I still wasn’t making contact with the battery tube…the gap on my light is pretty big it seems but ymmv.
The emitter shelf is the main bottleneck really, I wouldn’t drive the light above 4A without taking some serious time to beef up the thermal transfer of that thin emitter shelf. Even at the roughly 3A stock it’s really not adequate…
The heatsink/driver section of the light isn’t particularly massive or well finned as you point out but it does have a decent thermal path from there into the fairly massive battery tube through the raw aluminium threads. Thermal transfer forward into the rest of the head isn’t ideal because the threads on the two part head are anodized, but the combination should still suck a fair bit of heat out of the pill and dissipate it pretty quickly.
I don’t see any real problem with the kind of power you need to dissipate from a single XP-G2 or XML even when driven at up to 6A it should do fine.
Provided the pill is improved anyway.
I just retested this one with 3x 20Rs in parallel. It, well, sorta works. It's not entirely happy with the voltage, it makes a truly wicked squeal from around 40% up to 80%. It's fairly quiet at 100%, but still making some noise. It only sounds not too bad because of how loud it is before it gets to 100%.
Output is 4.10-4.15A, shorting the big sense resistor on the top board only bumps it up to 4.30A. It is much happier at 8.4v input and above, though I don't think it would be unsafe/unreliable at 4.2v. The squeal is from the driver itself, not any of the connections or other components. No squeal at 8.4v.
How wide is the top circuit board? That may be the biggest hurdle to getting this to fit.
1.31"/33.something mm.
The inside surface of the lower board has components out to within .070" from the outer edge, so the ledge the driver sits on can't be any wider than that.
I love this beast
on the left is the big head with dedomed stock emitter flowed onto noctigon, replaced wires, braided springs, r100 sensing resistor and smaller centering plastic
on the right is t08 dedomed xm-l u2 1c on noctigon, replaced wires, some resistors stacked up…
and damn! this thing throws
also I turned the emitter plate upside down to be able to focus better (get the led deeper into the reflector and create some pressure on the board) and pasted it a little - then tightened it really well
but I screwed up the stock driver a bit, it doesn’t turn completely off measured ~16ohms between L- and ground and couldn’t find where was it coming from oh well, it’s a nice nightstand light when “off”
