Wow FlashLion, great review! Very professional. This light to me, seems to be the perfect EDC. Side switch, (which I love in lights), simple UI, very small and powerful. What’s not to like?
I have the original S10 version, which I modded to upgrade the emitter to a 500k XML2 T6 neutral. Great light. I love the new shortcut the L2 version has to max.
The S10 is one of the best pocket EDC lights available.
The green tint is most definitely less severe than with the XM-L emitter, the S20 I had was quite green. The S10 I’ve got is slightly green in moonlight and low BUT I don’t think it makes any difference when you actually use the light. I generally use moonlight in the middle of the night, part of my business is looking after people’s dogs while they are away, and this often involves getting up in the middle of the night if the dog wakes me up for what ever reason - I promise you that at the times you need to use moonlight, you don’t notice the tint - but it is lovely to have a mode that doesn’t blind you!
Low is not much use out side, it just isn’t quite bright enough in my opinion (for walking) and the very slight green tint is not noticeable indoors when you are using the light on low, say for finding something or lighting up a tight space and so on.
I also think with current controlled lights you are going to have to accept some tint shift.
Agreed… for lower power settings. At max power there shouldn’t be much tint shift and I expect to not see any green tint.
Most of the greenish tint from the original S10 wasn’t caused by the emitter. It was actually caused by the coatings on the lens. Replacing the lens fixes it pretty easily.
