I love this beast
on the left is the big head with dedomed stock emitter flowed onto noctigon, replaced wires, braided springs, r100 sensing resistor and smaller centering plastic
on the right is t08 dedomed xm-l u2 1c on noctigon, replaced wires, some resistors stacked up…
and damn! this thing throws
also I turned the emitter plate upside down to be able to focus better (get the led deeper into the reflector and create some pressure on the board) and pasted it a little - then tightened it really well
but I screwed up the stock driver a bit, it doesn’t turn completely off measured ~16ohms between L- and ground and couldn’t find where was it coming from oh well, it’s a nice nightstand light when “off”
good to see some more of these lights in the hands of modders!
The hotspot it produces really is very nice once focused, dedomed it must be a beast. Nice one!
Did you manage to get a reading of tailcap current after the r100 resistor change?
Cheers
not yet, I’ll try to get a good reading this weekend across the tailcap
the hotspot is really nice, with a bit of flares
it got a brighter ring around the hotspot but that doesn’t bother me that much and I will not mess with the focus no more
On my light I would say yes it’s pretty much necessary for higher output. Definitely for overdriving an XML to the max. Maybe not for XPG but the stock solution is really not ideal.
janko.hrasko how was the tolerance of the pill shelf threads on your unit?
Mine was very loose, as in I could wiggle the shelf easily and by quite a large amount when it was partially threaded on and in the focus position, that’s the worst thing about the thermal transfer I think. Very few threads for a small contact surface, and loose as well. Putting thermal grease/paste on the threads helps but not enough really.
the shelf was very loose on mine in the focus point too… that’s why I flipped it upside down to tightly screw it against the rim underneath it
in stock there was a recess in shelf in which the led was sitting… now it’s higher on the flat part of the shelf and even the reflector is pressing on it from the front
the heat transfer seems fine to me, it’s getting pretty warm but not hot even when I’m not holding it - the whole massive body is working as a heatsink
Is there any chance you can take measurements between the bottom of the LED shelf once it is screwed in and the top most driver components? It looks like the clearance is around 30mm, but that is a total guestimate.
Sure, I’m stripping the light down again in a bit so I’ll take a bunch of internal measurements of everything
Ok here is what I came up with.
top of emitter shelf from top of heatsink when in focus
~2.7mm
thickness of emitter shelf
3mm (3mm-0.85mm for pcb cutout)
depth from top of driver board to emitter shelf rim
27.5mm
depth from emitter shelf rim to electronic switch port
~12mm
driver cavity inner diameter
34mm (33.98mm)
emitter shelf thread O/D
41.75mm
I/D of emitter shelf threads in body
41mm
depth of emitter shelf threads in body
7mm
thickness of driver board
1.6mm
height of driver at highest component (including board)
~12mm
diameter of flat base section on reflector
27mm
So Rod, if you want to know exactly the distance between the bottom of the emitter shelf when it’s focused and the top of the driver board.
It’s…
distance from top of the driver board to emitter shelf rim (27.5mm) + depth of emitter shelf threads (7mm) - gap from top of threads when emitter shelf in focus (2.7mm) - thickness of emitter shelf itself (3mm).
And if I didn’t mess any of that up it comes out as 28.8mm, so your guesstimation was pretty damn close
If you’re wondering about the size of the copper slug you could fit in there though, you’d have to take into account the height of the toroid on the driver (around 11mm) and the electronic switch port which is only 12mm down from the edge of the emitter shelf rim.
Easiest heatsink enhancement I think would be a 34mm X ~13.5mm slug (copper/aluminium) lapped and bolted to the bottom of the emitter shelf. Then drilled to accomodate the two emitter wires.
Starting with a 35mm bar it should be fairly easy to sand the O/D down a bit and also remove the anodizing on the inside of the driver cavity walls (and open it up a bit as well) to get the combination close to being a press fit.
At least that’s what I’m going to be attempting I think, I have 35mm aluminium bar stock at hand and it should be doable without heavy machinery…I hope
Better would be to machine a whole new pill out of copper with threads and everything but that’s definitely out of my league, and I’m pretty sure a lathe is mandatory for something like that…
Many thanks for the info. I am hoping the heatsinks which I ordered from FT arrive within a couple of weeks. A copper slug of around 10mm in height might do the trick if I can find said slug in a hardware store.
Thinking out loud, the plan is to place the LED shelf upside down. With it upside down, the area where the LED is supposed to occupy, there will be a 20mm copper slug in its place. The surrounding area, I will place heatsinks which are 5mm in height. I will have to rely on the threads to transfer the heat collected to the body.
Also, with the shelf upside down, it should focus the LED better as suggested by janko.hrasko as it is sitting up closer to the reflector rather than the default position.
The problem with this approach is you’re not really doing much to improve the thermal path away from the shelf and to the outside. It will work well initially to suck and store heat from the led but the real weakness of the shelf is not really it’s thinness but that it can only transfer heat to the body through it’s small and loosely machined threads with minimal contact surface. Upside down or not the contact area is still pretty minimal and that will be the main bottleneck.
The idea with adding a 34mm slug that fits down into the driver cavity is that this will both collect and transfer the heat out along it’s own contact points to the driver cavity walls. Even if the press fit isn’t optimal you can increase/improve the contact area very easily with a few layers of copper or alu foil.
I’m pretty sure that will do a much better job at keeping the led cool than relying solely on those threads on the emitter shelf. You’ll see when you get the light, they’re pretty suboptimal…to put it kindly. :bigsmile:
Incidentally how easy/hard is it to remove anodizing on a specific part of a light without destroying the rest. Like could I paint on the degreaser/greased lightning only to the inside of the driver cavity and let it do it’s thing or would just sanding the coating off be a much better idea?
flipped shelf isn relying solely on those poor threads… it sits tightly on the rim and with some thermal paste there it isn’t that bad
sure copper pressed really tight would be better but I don’t think that it matters to me that much to have someone machine it for me
I got tailcap lockout!
just unscrew the tailcap, unscrew the b- pcb, take it out
screw the three screws that were holding it to the body
place the pcb OVER the screws
get something that can create pressure on the pcb from the tailcap (I used a lid from film canister) and place it over the pcb
screw the tailcap on and BAM!
when you tighten the tailcap, it pushes the pcb on the screws and completes the circuit
loosen it a bit and the pressure from the springs breaks the contact
Update: I ordered a custom firmware driver from DrJones (mokkadrv - 4 mode) that I’ll be using in this light.
Probably won’t do much work on it till I get this driver, too many projects on the go and I really need to get my BTU-MTG2 monster project finished up.
But I’m keen to see what others are coming up with in the meantime so feel free to post any progress or ideas in this thread so we can have a collection of useful info on this light.
If anyone has any questions or wants any measurements let me know, the light will stay disassembled for now.
Linus. I’ve just encountered the same type of threaded emitter plate on the Yupard I started working on. The COURUI has an integral ledge that the plate threads down onto, but mine doesn’t. I can’t add extra heat sinking that will transfer heat into a ledge that is part of the head.
Allegedly, anodizing doesn't affect the thermal properties in a significant way. It might be measurable, but that doesn't mean much. If your wife says 'it's cold in here!' and you raise the temp from 63.4* to 63.8*, that's measurable, but probably not likely to do anything to stop the complaining. :)
A change in output of 1 lumen is measurable, but how much work would you be willing to invest for one lumen? How many lumens would an improvement have to be to be worth whatever work required to get it?
