Test/Review of Efest 16340 850mAh (Black) 2014
6 posts / 0 new
HKJ
HKJ's picture
Last seen: 12 hours 18 min ago
DSC_4124
Official specifications:
  • Min Capacity: 850 mAh
  • Typical Capacity: 850 mAh
  • Nominal Voltage: 3.70V
  • Size: Max.16.63x33.98mm
  • Weight: 25g
Efest%2016340%20850mAh%20(Black)%202014-info
The capacity is specified way to high as it usual is with 16340 batteries.
DSC_4123
DSC_4125 DSC_4126
DSC_4127
DSC_4128
Efest%2016340%20850mAh%20(Black)%202014-Capacity
The battery has a very stable capacity, independently of load. This is much better than last time I tested this battery.
Efest%2016340%20850mAh%20(Black)%202014-CapacityTimeHours
Efest%2016340%20850mAh%20(Black)%202014-Energy
Efest%2016340%20850mAh%20(Black)%202014-PowerLoadTime
Efest%2016340%20850mAh%20(Black)%202014-TripCurrent
Efest%2016340%20850mAh%20(Black)%202014-Charge
Conclusion
The battery does not have the highest capacity of 16340 batteries, but it does a good job in the 1A to 2A range, making it a good fit for many flashlights.
I will rate the battery as acceptable.
Notes and links
Comparison to other LiIon batteries
Chloe
Chloe's picture
Last seen: 5 years 6 months ago
Thank you for the review, HKJ! It appears the cell is dented. Was there any damage to the box?
HKJ
HKJ's picture
The cell is not dented, but the label has a bump where it crosses the protection strip.
For people that are in doubt about the construction of a protected battery, check here: http://www.lygte-info.dk/info/battery%20protection%20UK.html
RaceR86
RaceR86's picture
Last seen: 5 years 11 months ago
Thanks HKJ. Looks like Ill stick to my 550mAh red V2 since its better at high current. Smile
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
HKJ
HKJ's picture
RaceR86 wrote:
Looks like Ill stick to my 550mAh red V2 since its better at high current. :)
No surprise there, IMR is supposed to be better at high current.
RaceR86
RaceR86's picture
Yupp... Smile
