I've got one ordered from manafont. Wife wanted a small light with a twist switch so... I'll try and post something when it arrives.
https://budgetlightforum.com/t/-/1576
https://budgetlightforum.com/t/-/2761
At least two reviews on this forum ....
I bought that light for my daughters keychain. It is xpc and it is tiny. A little longer than the ITP EOS but thinner. Overall I feel it is smaller. She loves it, I have not played with it much but it seems like a nice light. Holding together nicely on the keychain. Not super bright output but for a single mode it seems just about right for what it is. When I get some time I will figure the lumen output.
Yeah, 1 mode you don't want to be too bright anyway. The tmart SS c3 is only very lowly 0.5a draw. Wonder if qtc works here though.
I HAD this light but my 3 year old lost it somewhere :(. It was a really nice little light for what it was. It was as bright as a keychain light needs to be. It also had a really really nice neutral tint. Just a heads up the grey protected trustfire 10440s are too thick to fit in it. Even so, with just a regular alkaline it was plenty bright.
I hope she doesn't have a glow in the dark belly button now....
My bad S1 - S-A1 , was late - to much Duke Nukem !
On a 1.34V Rayovac precharged NiMH, 66.66 lumen. Im pretty bad at tints but I would say pretty neutral. Iād love to have an XML like that.
Sorry DP
I also have one of these and can confirm it's an XPC emitter. The tint on mine is very warm though, at least compared to everything else I have. I bought mine from a local chinese vendor (I'm in china at the moment), I'm planning on sticking a QTC pill in there when I get back stateside. It gets a little warm when left on for too long, and that's just on alks. I just ordered a 10440 for it anyways, though.
No problem... Nuke 'em 'till they glow, then shoot 'em in the dark! ;-)
BTW... seen the Steam summer camp sales? US prices for the Valve complete pack is nice and even nicer in the UK.
Oh. That's interesting. I've had a S1 on my keychain for a couple of months now and my old protected, grey TF 10440s fit fine. DX screwed up my order so, unfortunately, I don't have any other 10440s to try out. I'll try to upload a couple of pictures later. And I agree with you: the S1 is a really nice light. Small, light, bright, cheap, what's not to like? Just don't keep it on for too long if you're going to be using 10440s.
I'll try to upload some pictures in a bit...
Here we go.
guess i just got a crappy pair. i didnt try all my 10440s. i just grabbed the closest one and didnt bother to keep going after the first. i have noticed a lot of variance in the length of my red/black trustfire 18650s, so its np surprise that some fit
It looks like it has a decent brass pill. Can anyone confirm that?
What I'm also wondering is if the R5 star and driver from the Ultrafire A2 R5 may transplant. Shouldn't be too much of a problem if the S1 has a decent pill.
I kinda fancy this dinky small SkyRay S1 with an R5.
QTC isnt easy to get to work in this one.
The base has a spring that is about 1/2 inch long so QTC wont work there without major modification. On the nose, the contact is made between the head and a shelf at the base of the threads so again, not a good spot. I tried it between the head and the nose on the battery but couldn't get it to line up and work very well as the base spring seems to have more give than the QTC.
That's disappointing news.. Are you using a 10440? Maybe try using some spacers?
tried with both a 10440 and a standard alkaline. it is just not a good arrangement for Qtc. I think the tank E07 is a much better bet although being a AA is a larger light.
The way this one is designed, the positive contact is made full time because the spring keeps the battery in contact with the center of the driver, the negative contact is made between the outer ring on the driver and the light body only if/when the head is screwed all the way down. There is no way to use the qtc unless you could pin it between the shelf on the body and the driver rim. That shelf is maybe .5mm wide and sloped thus making it extremely difficult to get anything to fit and stay in place.
I had hoped it might be a good one for QTC use but it isnt. I'll probably get a black cat next. I found a pic of one disassembled and it looks like a good candidate for Qtc treatment.
I had one of these that I had purchased for the sole purpose of modding to a QTC light. I would take pics but I gave it away as a gift already to my stepbrother. To make it work with QTC, you're going to need to remove the base spring, find or cut a solid metal disc that will rest at the bottom (this is where the experimentation comes in to find the right size. Drop a QTC pill on top of the disc and try it out - if it doesn't turn on, you're going to have to raise or change the size of the disc. Once the proper height/size is achieved, you can use electrically conductive epoxy to hold the pill in place, or if you have the machining capabilities - make a divot in the disc to hold it. Works great!
Edit: I did strip the ano and sand the light first, so the threads may need to be bare to work perfectly. It's a fairly easy light to get apart and the ano comes off like mud on dirty shoes if you use Super Clean.
Edit edit: Conversely, you can just remove the base spring, then use small neodymium magnet discs (the thinner the better) and attach them to the positive end (be careful not to short out your light) to find the proper height, then fabricate a post of the same height and solder it to the positive contact of the light.
