Hey, Ric! While the shell idea is nice, and I’m glad it is possible, I think what we’d all like to see even more is the 3*XM-L drop-in made available so we can use it in Maglites or Tr-1200’s or whatever it would fit. 52.8mm would be nice along with the same driver that’s in the skyway.
Yeah, I know. I just wish they would not get my hopes up. These drivers are becoming my #1 pet peeve. If I remember right the low isn’t that low either.
USD30 with HK Registered shipping is good. Paypal sent.
They sent out my Yezl M7X within 2 days. Nice.
[/quote]
Not sure what's the use for low on a light of this nature. For flood light, the low is already low enough as its "spread out" - not very bright. I don't use the low on my Dereelight DBS aspheric. :)
I only hesitate to pull the trigger until I see from others how it performs with the bigger lens. I put a 28.5mm aspheric on my L2 (xm-l @ 2.8A) and the focus was perfect but it was dim as hell and not worth crap. The worse thing ever. If this turns out good I'll get one ASAP.
If you have any zoomies at present , cccpull, then take a look at the lenses on them. The lenses on all zoomies are aspheric, that's how they are able to zoom. Moving that lens closer to or away from the emitter simple changes the focus of that lens.
This light fits into the scheme of things together with a dedicated thrower of 1 x 18650 like XR-E R2 of 52mm bezel size, like a Dereelight DBS V3 XR-E R2 aspheric. Or those who have Solarforce MPP-1.
Hotspot is 13cm dia @ 1m dist. Ultrafire U-80 of 42mm bezel is 14cm dia. UF-980L is slightly larger at 14.5-15cm.
This light would not give you spill, perfect on reflective grounds...esp snow or sand, in which the spill would hurt your dark adapted vision and ability to see the hotspot/ID objects. On grass and soil/hilly terrain its probably ok.
How aspherics perform vs big ass reflector lights. You can see the 73mm reflector XM-L doing 80K lux @ 1m, slightly more than a 52mm XR-E R2 aspheric.
