BIG HEAD Yezl T9 CREE XM-L T6 1x18650 Zoomable Flashlight
Thanks Ric, I just sent money for 3 more.
Dear sir Ric-CN,
Thanks for doing this. Out of curiosity, if you manage to get the flashlight bodies for this flashlight... any idea at what price it can be available?
Also are there many other interesents for this? I'm sure i am, for a few at least.
Thanks, Ric-CN!
I just sent the money.
I only hesitate to pull the trigger until I see from others how it performs with the bigger lens. I put a 28.5mm aspheric on my L2 (xm-l @ 2.8A) and the focus was perfect but it was dim as hell and not worth crap. The worse thing ever. If this turns out good I'll get one ASAP.
Is there a holster available for this light?
Does the Ultrafire BRC 3000 mah 18650 fit in this light?
Thanks
But this isn't an aspheric lens.
If you have any zoomies at present , cccpull, then take a look at the lenses on them. The lenses on all zoomies are aspheric, that's how they are able to zoom. Moving that lens closer to or away from the emitter simple changes the focus of that lens.
Only have one "zoomie", Led Lenser T7. Always thought of aspheric lights as fixed focus (outer dome lens) throwers.
PS Like the ones on 2100's post
This light fits into the scheme of things together with a dedicated thrower of 1 x 18650 like XR-E R2 of 52mm bezel size, like a Dereelight DBS V3 XR-E R2 aspheric. Or those who have Solarforce MPP-1.
Hotspot is 13cm dia @ 1m dist. Ultrafire U-80 of 42mm bezel is 14cm dia. UF-980L is slightly larger at 14.5-15cm.
This light would not give you spill, perfect on reflective grounds...esp snow or sand, in which the spill would hurt your dark adapted vision and ability to see the hotspot/ID objects. On grass and soil/hilly terrain its probably ok.
How aspherics perform vs big ass reflector lights. You can see the 73mm reflector XM-L doing 80K lux @ 1m, slightly more than a 52mm XR-E R2 aspheric.
http://www.candlepowerforums.com/vb/showthread.php?312428-TRA-66-Aspheric-lens-Flashlight-150-000-lux
http://www.candlepowerforums.com/vb/showthread.php?312645-TMA-66-XM-L-Aspheric-lens-Flashlight-100-000-lux
I ordered one 07/01 with EMS. It's still unshipped. Ric, please check my order #2011070127792
hi Ric i am ordered two Yezl t9 in the web,(order 2011070663676). i paid via paypal , and in the order status appears as unpaid. my user is gonzapi
thanks
If it is significantly better than this Review: Yezl T8X MK II Raptor I will order one. I hope it is better.
Ric-CN, 30USD sent for one Yezl T9.
Transaction ID # xxxxxxxxxxxxxx433S (PM me for complete ID if required.)
I found beamshots!
I was getting worried about the lack of reflector but this seems quite strong. If anything, I will have to find a way to add in a reflector to make the XML more efficient but it looks good from these pictures!
Kind of strange the other yezl lights have 3 mode w/o blink and this is 5.
I just checked, it,s still unshipped. That's a very bad service. If it,s still unshipped tomorrow, I will cancel it.
So how are we going Ric on that postage? Have you sent them yet?
It's more like either aspheric or reflector. If you use both, the reflector will only result in a quite ugly spill pattern.
Hm, does look interesting. Maybe the red is a bit more forgiving :) I've seen uglier images, e.g. here.
Here's my favorite, one of the worst things you can do in that respect, MCE with OP reflector and aspheric :)
The light that is caught by the reflector only gives that outer ugly spill, it does not contribute to the spot at all.
Well, it's still unshipped. I decided to give them a last chance. I used their message form and I made them some kind of an ultimatum.
Edit:
I just saw I have got a private message from Ric. Apparently it is shipped now, but the the info on my account was not yet updated.
