WOW, he already replied.
2.5A current, doesn’t know if it is DD.
Enigma continues.
Darnit.
Don`t forget that these are about $30 with the older XML, and replacing it with an XML2 would be cheaper than buying this off the bay.. just my 2 cents..
The Tmart Tangsfire HD2010 is only $31 last I checked (Many have grabbed one, they all had East-092); you can put a noctigon + xm-l2 in it for cheaper than this listing.
Edit: Chibi beat me to it. .
-I think every time I look at an HD2010 I have to reiterate how great HD2010’s look… Perfect dimensions, beautiful light all across the board.
I just got my first HD2010... standing in front of me.. I also like how it looks... but mine has a centering issue...
anyway.. I will do a little modding with it, nothing extreme though... mainly keeping the same components it already has.
If it’s the star that isn’t quite centered try an O-ring around the circumference of the star in-between the 16mm star and the lip of the pill. It looks a bit ghetto, but it works very well. The star may be thermal glued, so you might have to deal with that too.
Mine was a bit of a pain getting centered and focused to my liking, but the end result is fantastic. Definitely has an amazing quality feel in one’s hands to boot.
There is a black 3-mode version at Willbuying for $33…
Never ordered from them, but supposedly they take PP and shipping is free (based on my zip search). Got the link from the Youtube video by them…
Looks pretty darn impressive, I must say.
I emailed them and they told me they have checked each side by side and the XM-L2 version is much brighter than the old one.
That 2.5A reply above form the eBay source was probably from some ***Fire cell, measured with a cheap DMM - thin leads. It's probably direct drive. I've seen sooo many single cell lights that come with direct drive drivers, and you don't really know til you try a low resistance cell and see the thing scream. Of course thin wires, a cheap driver spring, and XM-L2's will throttle it down but that's what they count on. I believe the direct drive drivers are the cheapest and that's why we see them in a lot of stock lights. The thin wires and poor springs keeps the amps in control somewhat.
I agree. This thing just has too good a body, making connections such a dream that I just ordered the one from Willbuying. I figured, what the heck.
Got my HD2010 from Tmart with $3 off $20+ purchase code D3.
Hopefully it comes with an East 092. Now the hardest part is always waiting.
That WillBuying one says "Hi-Med-Fast Strobe". The original East-092 was H-M-L-Strobe-SOS, right?
-Garry
An update, finally got my first high draw batteries NCR18650PF; I get 2.8A tailcap with 10gauge leads. XM-L2 on noctigon, ‘east-092’ driver, upgraded 18gauge wires, stock springs.
I believe this confirms that I got a dud Tangsfire HD 2010.
Guess it’s a good thing my Nanjg’s and extra chips arrived; I’d like to see this run at 4-5A.
i have yesterday one buy on tmart with D3 coupon and 300 points (love you tmart)
http://www.tmart.com/HD-2010-CREE-XM-LT6-8W-1300-Lumen-5-Mode-LED-Flashlight-Torch-Gray_p135765.html
i hope this is the good driver for one xml2 replace?
Also ordered the same but from US warehouse.
Will have to see how long before I receive it.
I have experience with the Ultrafire HD2010 from willbuying and that ebay listing looks similar, certainly it’s using the same photos.
Here’s what I wrote in a thread about willbuying deals in general.
Ultimately I was very impressed with this HD2010 and if they are all like this, I’d happy recommend them even if they cost a little more. The reflector is also the easiest HD2010 reflector I’ve delt with in terms of getting a really tight focus without much messing around. So either the Ultrafire reflector is machined to tighter tolerances in general or I just got lucky with my sample.
Cheers
if i buy this driver and LED displays a significantly better result?
http://intl-outdoor.com/qlite-reva-71358-multiple-modes-circuit-board-304a-p-710.html
http://intl-outdoor.com/noctigon-xm20-mcpcb-cree-xml2-u2-1a-led-p-749.html (cool white ?)
(with Panasonic 3400 protected)
or are there better drivers/leds for this light?
i wanne good little clear focus about 100-200 or more meter
thanks for replay and suggestions to al .
I’ve got that led in my hd2010… And my DST… A few other lights and soon to be a few others. it’s a fantastic LED.
I’m planning on putting that driver, with more chips stacked, on my hd2010 as well. It’s supposed to be a great driver.
Just got this light today. Review will be forthcoming. Came without so much as a scratch. Popped in an 18650 and then a 26650, and…yeah, it’s definitely brighter than the old T6 version, especially on the 26650.
Gotta get it outside tonight and bounce the beam off some trees before I elaborate more! J)
All my old East 092s, those with bright clearly marked Gold Etched — easy to read —East 092s all pulled over 4 amps. Now, I just ordered some from FT, and the MCU is marker DTU , 06N03 , DC50U, and even on a Powerizer only do 2.7 amps. Now, the Tangsfire Grey, that I got from Tmart on the Christmas special, has the exact same markings as the ones from Fasttech with the hard to read-smeared East 092 Logo. However, in the flashlight, it pulls 3.7 amps. There is a thread in here somehere, when the East 092 started to go bad, and even had different components. I am not happy with the new ones from Fasttech, definitely way inferior from the old “good” ones. So, getting a light with an East 092 can be a happy day or a super bummer …
It probably won't have greater output. The HD2010 has a direct drive driver. The Qlite limits current to about 3 amps. If greater output is your main priority, then get that LED/MCPCB, thicker silicone wires (20 awg should do) and a lens with an anti reflective coating. Do the spring mod and shave the centering ring too. You can get a copper pill from forum member ryansoh too.
If you really want the Qlite, which is understandable because it has a nice set of modes, and still want lots of output, then you'll need to add more 7135 chips. If you can't add chips yourself, you can get it from Mtn Electronics, or get a similar driver from DrJones.
