I do agree its expensive. More than I should have spent. I got in the first batch and was a little cheaper at $336, but still pretty bad. I can only justify the cost possibly by how dominate it is in performance. I mean this thing has almost as much throw as my Supershocker, but has 2200 more lumens. It’s not that far from a TN31 running at 6.5a. And it has, what - 4700 more lumens than it does. There really is no other led that can truly compete with it. Not even modded. Not even a modded TRJ18. And the X60vn does this while running at a reasonable 4-4.5a. Stock it has a 2hr runtime on high, but even at this level it will likely do well over an hour. And yeah its suppose to kick down at some point. But that “lower” level will still be about 5000 lumens. And of course you can still kick it back up if you want.
As for leaving the domes on, I thought about doing that too. But now seeing the serious flood and wall of light the X60vn puts out even dedomed, I just don’t think keeping the domes on will benefit enough to counter what I would guess to be a 200k+ loss in throw. It would still be very impressive in that setup too though.
I figure I can dedome later if I really want more throw. I'd probably upgrade the emitters of the XM-L continues improving anyway, which is a great time to try something different. If I do get this light, I'll also get a BTU that's dedomed. V54 gets really good prices on the BTU, so I might have him mod it too. It's kind of depressing. I want to do it myself, but there's not much point if it costs about the same to have the work done for me.
That 2nd link is an interesting light. Looks pretty good. If you can put one of those beast drivers in it, I think it would be a neater light than the TRJ18. I’m sure those 12 LEDs would heat up pretty quick though with the 90mm head. Would be an impressive flooder if not driven too hard.
Thanks for the suggestion leaftye. I am aware of those lights.
I already have a sick modified multiemitter light. Form factor is not what I find interesting. The large 5 emitter reflector is what I am drooling over. :)
Thanks for the mini-review. Im sure you’re very proud of your light and have every reasons to be. Just the fact that the host isnt glued in this category of light makes it that much more appealing. If this were a larger & deeper reflectored light (such as an upscaled BTU reflector) Id bite in a heartbeat and gladly kick out the $. Of course everything is a compromise, and this light would easily serve a great many needs while satisfying expectations.
Vinh says the X60 actually comes stock with a copper pill that the LEDs sit on. He basically took it out, sanded the surface smoother, reapplied the xml2’s on copper Sinkpads onto this copper pill. Of course dedomed. He then did a resistor mod to bump it from appx 3A stock to its current 4-4.5A range. He then did wick mods on all the springs, touched up any connects needed and replaced all the main wires. He said stock it was setup pretty nice. But with him boosting the amps he wanted everything bumped along with it.
That’s the first stock light I’ve heard of running on a copper pill, interesting. Though running it on copper doesn’t really make much sense with the conservative 3A drive.
It does when it costs 300,000 cents! I like that they've improved the headroom for this like. The Thrunite TN-32 also has a copper pill, except the copper extends to the exterior where it can have the greatest effect.
Sorry, but no. Way too difficult for me to do during the work week. I live in the city during the week, but head to family country house on weekends. This one, and many of my lights are too powerful to use around town without attraction too much attention.
In fact, I had my X60vn out shining across a field close to the house this past weekend. Maybe 300m away at a treeline. There are houses perhaps 20deg or so away from where I was shining (same distance away). Only had it on for perhaps 10 seconds.
Went back about 15min later with a few other lights to try in comparion to the X60vn. And guess what I find - squad car sitting right in front of the treeline I was shooting at, sitting in the dark, faced my direction. Had to get binoculars out to make sure it was a cop. No mistaking the lightbar on top.
So no more playing in my neighborhood with the powerful lights.
If the weather cooperates this weekend I’ll get some shots done. Its suppose to be a decent chance of rain, so we’ll see how it plays out.
Any particular lights you want to see it compared too?
