Hi there Daniel,
Can you tell us when you post a new light, if the driver pill is glued in or easy to remove and upgrade?
I seem to have the mod bug, and knowing would help
Hi there Daniel,
Hi FlexakaMal,
I'm sorry ,I can't reply your question ,I only post there new arrival products ,thanks !
if you have a special need ,we also can help you find it !
Thanks very much !
Daniel
SmallSun ZY-016 LED Flashlight Features
- Brand new and high quality LED flashlight
- Compact and portable design
- SmallSun ZY-016 SSC-P7 5-Mode 130-Lumen LED Flashlight
- Powered by 1x18650 batteries (not included)
- Toughened synthetic glass lens and textured coated plastic reflector cup
- Durable Aluminum Alloy housing
- ON/OFF power switch by pressing the end of the torch body
- 5 modes: Hi > Med > Lo > SOS > Strobe
- SmallSun ZY-016 LED Flashlight with built-in strap for carrying conveniently
- Perfect fit for home maintenance, outdoor activities, hiking, night fishing, camping, caving, hunting etc
SmallSun ZY-016 LED Flashlight Specifications
Color: Black
Brand/Model: SmallSun ZY-016
Lumen: 130 lumens
LED emitter: SSC-P7
Lens diameter: 44.6mm
Length: 150.0mm
Weight (including the packing): 159.0g
URL for this flashlight: http://www.lightake.com/detail.do/sku.29212
SmallSun M8 Cree MC-E 5-Mode 250-Lumen LED Flashlight Features
- SmallSun M8 Cree MC-E 5-Mode 250-Lumen LED Flashlight
- Powered by 1x18650 or 2x16340 batteries (not included)
- Coated glass lens and textured Aluminum orange peel reflector cup
- SmallSun M8 LED Flashlight with built-in strap for carrying conveniently
SmallSun M8 Cree MC-E 5-Mode 250-Lumen LED Flashlight Specifications
Color: Black
Brand/Model: SmallSun M8
Lumen: 250 lumens
LED emitter: MC-E
Lens diameter: 44.5mm
Length: 146.0mm
Weight (including the packing): 75.0g
URL for this flahlight:
http://www.lightake.com/detail.do/sku.30683 (black)
http://www.lightake.com/detail.do/sku.30682 (gray)
Bolly BL-801 Cree P3-8B 150-Lumen Yellow LED Flashlight Features
- Bolly BL-801 Cree P3-8B 150-Lumen Yellow LED Flashlight
- Powered by 1x18650 battery (not included)
- One mode reverse clicky
- Bolly BL-801 LED Flashlight with built-in strap for carrying conveniently
URL for this flashlight: http://www.lightake.com/detail.do/sku.30783
901 Cree Q3-WC 3-Mode 130-Lumen Convex Lens Zooming LED Flashlight Features
- 901 Cree Q3-WC 3-Mode 130-Lumen Convex Lens Zooming LED Flashlight
- Coated glass lens and Plastic Smooth/SMO reflector cup
- 3-Mode: Hi > Lo > Strobe
- Features: Twisty head turn right can be square beam of light; Twisty head turn left can be circular beam of light
- 901 LED Flashlight with built-in clip for carrying conveniently
URL for this flashlight: http://www.lightake.com/detail.do/sku.30786
MrLite LT1 CREE 7090 XR-E R2 9-Mode 230 Lumens LED Flashlight Features
Brand New MrLite LT1 CREE 7090 XR-E R2 9-Mode 230 Lumens LED Flashlight
Pocket size, portable for everyday carry.
Precision optical system, latest orange peel reflector
Mil-Spec type III hard anodized finish, impact resistant
Made from aluminum alloy, really strong
Water proof to IPX-3 standard
IC control
Maintain constant brightness
Variable output mode:
2 modes with 9 types output
Normal mode: lowlight, normal light, high light, strobe, and stand-by
Professional mode: slim light, lowlight, normal light, high light, super light, strobe, low light SOS, high light SOS, and stand-by
Ergonomics design for comfortable handling
Toughened ultra-clear glass lens with anti-reflective coating
Replaceable and rechargeable lithium polymer battery
Low heat emit
MrLite LT1 CREE 7090 XR-E R2 9-Mode 230 Lumens LED Flashlight Specifications
Color: Black
Dimension: head diameter 29 mm, tail diameter 29 mm, and length 112 mm
Lumens & runtime:
Level1: 230 lumens, 2 hours
Level2: 180 lumens, 2.5 hours
Level3: 160 lumens, 4 hours
Level4: 90 lumens, 9 hours
Level5: 40 lumens, 26 hours
Material: aircraft aluminum alloy T6061
Weight: 118.5.0g (exclude battery)
Water proof to IPX-8 standard
Battery: 1 x 18650 (not included)
LED power consumption: 3W
Reflector: OP
Switch: Reverse switch
MrLite LT1 CREE 7090 XR-E R2 9-Mode 230 Lumens LED Flashlight Package Included
1 x MrLite LT1 CREE 7090 XR-E R2 9-Mode 230 Lumens LED Flashlight
1 x Nylon holster
1 x Lanyard
1 x User's manual
UltraFire WF-501B Cree MC-E 800 Lumens LED Flashlight Features
- UltraFire WF-501B Cree MC-E 800 Lumens LED Flashlight
- Powered by 1*18650 battery (not included)
- Maxium Lumens: Output up to 800 Lumens (manufacture rated)
- Glass lens and aluminum orange peel reflector cup
- Constant current circuit, voltage range: 3.0V-4.2V
- Come with Cable Pressure Switch for UltraFire WF-501B
- UltraFire WF-501B LED Flashlight with built-in strap for carrying conveniently
UltraFire WF-501B Cree MC-E 800 Lumens LED Flashlight Specifications
Brand/Model: UltraFire WF-501B
Emitter Brand/Type: Cree
Emitter BIN: MC-E
Lumen: 800 lumens
Reflector: Orange peel reflector
Color: Black
Lens diameter: 30.0mm
Length: 135.7mm
Weight (including the packing): 122.0g
UltraFire WF-501B Cree MC-E 800 Lumens LED Flashlight Package Included
1 x UltraFire WF-501B Cree MC-E 800 Lumens LED Flashlight
1 x Cable Pressure Switch for UltraFire WF-501B
More Ultrafire Flashlight: http://www.lightake.com/products.do/category.176
Coupon on lightake FLASHLIGHT 5% discount
Only used for the flashlight products
Very nice
Romisen RC-27 Cree Q3-WC 3-Mode 100-Lumen LED Flashlight Torch Features
- Brand New Romisen RC-27 Cree Q3-WC 3-Mode 100-Lumen LED Flashlight Torch
- Compact and portable handheld design
- Powered by 2xAAA batteries (not included)
- Coated glass lens and Plastic Smooth/SMO Reflector
- Constant current circuit, voltage range: 3.0~8.0V, 8.0V Max.
- 3 modes: Hi > Mid > Fast Strobe
- Romisen RC-27 LED Flashlight with built-in strap for carrying conveniently
Romisen RC-F7 LED Flashlight Features
- Brand New Romisen RC-F7 Cree Q2 90 Lumens LED Flashlight
- Powered by 1xAAA battery (not included)
- Romisen RC-F7 LED Flashlight with built-in strap for carrying conveniently
Your history of posts and the way that you have read the posts of others makes it more likely that I will order from your organisation. Please make it clear to your competitors that there is a right way and a wrong way to advertise. Seems to me that you have chosen the right way. Keep up the good work.
I had placed an order when the introductory coupon was valid and now that there is a new coupon for "us" again, i placed another order today. :)
Thanks very much ,I will follow this froum's rule ,thanks again!
Product Features
- Super bright flashlight torch
- Powered by 1*3.7V “2400” 18650 battery (included)
- Come with an AC charger and charge dock
- 5-mode switch: Hi >Lo >Mid >Strobe >SOS
- Durable aluminum textured reflector
- Flashlight with built-in stripe for carrying conveniently
Specifications
Lumen: 200-lumen (manufacturer rated)
LED Emitter: Cree Q5 LED
Length: 148.4mm
Net weight: 169.5g
Weight (including the packing): 483.0g
Components: 1* Flashlight Torch, 1* 18650 Battery, 1* AC Charger, and 1* Charger Dock
Get a 5% discount buy it now !
New vision of our website,more beautiful ! and have more functions !
Site looks good, I especially like the 'mouse over' picture zoom, speeds things up a lot.
I see you've fixed the search function, well done.
Was just about to put in an order yesterday but I read on another forum that lightake.com would start a new promotion in 24 hours.
I know I'm being quite cheeky for asking but will the new promotion entail more than 5% discount?
Thanks for you like it ,now there won't have a coupon more than 5% discount ,and next week ,we plan have a promotion only for one flashlight ,and maybe get a 10% discount for this products,which products we still didn't determind ,can you recomment me a flashlight to have a promotion,and this product also have a max amount ,maybe only offer 5pcs for this product can get this discount !
any suggestions are welcome!
Thanks in advance!
Daniel
My vote would be for one of these two -
http://www.lightake.com/detail.do/sku.Romisen_RC_C6_LED_Flashlight_Black-29193
http://www.lightake.com/detail.do/sku.TrustFire_Z1_LED_Flashlight_Gray-30310
Thanks for doing this.
