louis huang -- can you verify the specs listed for this light having a true XM-L2 U3?
-- of course if you answer "Yes", I won't believe you but would be interested in some sort of proof, evidence or reason why you think it may be a true XM-L2 U3 binned emitter from CREE. We can all tell it's in the family of XM-L2's from the white background on the surface around the phosphor/silicon covered dome, so that means it could be a T6 or U2 (U3's are extremely limited of course).
I'm more interested if he replies to my U3 question , doubt he will reply though. I'm just hoping it's a standard size C8 pill, standard C8 threads, etc. I'm thinking it should be, similar to the LightMalls C8's. I did buy a TMART C8 a while back and think it was all standard sizes, but that was with an SS bezel, different I'm sure from what they are selling now. If he does respond saying it's a confirmed U3, then that will be enough to encourage me to do some head to head testing against T6's and U2's.
+2 I have the east 092 driver in an HD2010 (looks like C8 on steroids) and it pulls 4 to 4.5 amps on High using a protected 26650 trust fire flame battery. A protected battery has a small computer circuit board on the bottom that protects it from over charge, over discharge & high current draw.
Terms are rather confusing. I read: 1. expires tomorrow 2. One time order per ip 3. Can order up to 30 for the one time order — the deal is not limited to total 30 lights. Suggest typing in the discount code rather than copy and paste.
well, I read/understood it as: 30 lights total for the discount price (i.e. 30 uses of the coupon code), 1 light per person only.
When a co-worker tried buying one however, his order got rejected, saying only one piece allowed (something like that). So from that message, I could only assume they were checking on IP addresses because he was using a different TMART account, but the IP address is the same as the IP address I used (same company network, appears as one IP address externally). Later, someone else at work tried it, but by logging into their remote home PC, and got rejected saying all coupon codes are used up (something like that), so I assumed 30 orders were already made.
I knew these would go quick... Good deal and from the US warehouse.
5A is up there if you left it all stock with the thin LED wires, no copper wired springs. Not surprising you got it that high though - still aluminum star and those SONY 30A's are an incredible cell - on par, maybe better than the Sam 20R's. 5A's on an aluminum star though can be dangerous, but the SONY 30A's sure won't last too long at that high amp range.
They are only 1600 mAh, so good for a couple of mins of high lumens glory . I've used these things in Super Shockers, and other high amp lights and they are great to see capability, and best possible output/throw you can get, but practical usage is somewhat limited for sure. I call them the SONY 30A cells for short. Very similar to the high amp SONY 26650's - great for testing with, but at 2600 mAh or so, not practical for a 26650.
Be very carefuly with these things, like the Samsung 20R's. For direct drive lights (East-092 drivers, etc.) and others out there, you get in some dangerous level of amps at a full charge. If you use a high amp regulated driver, these type of cells are the best to reach those high amps, not for long though...
Mine came in today, good tight spot with very mild rings in the spill. The threads were dry but all clean. Takes a 3400 protected cell easily. Metal reflector, almost no noise on the lower settings. Worked fine straight out of the bubble mailer. Good build quality overall, even the glass was clean for a change.
Got my TangsFire XM-L2 U3 today. It pulls 4.65A on a fresh Pana PD - 1,054 lumens @start, 976 lumens at 30 secs. I'd expect a big drop for 4.65A on an aluminum star. Tried the threads - yet another C8 thread size and cut, oh boy... Really was hoping it was going to be a true C8 thread. The pill threading is bigger than a Convoy C8 and UF T-20/LightMalls C8, so no chance brass or copper pills will fit. Like a Convoy C8, it came with a 16mm star - kind of surprising.
The body and reflector are clean - excellent condition. It's not bad, was hoping a little more compatible though.
Really really doubt it's a U3 - 4.65A and 976 lumens?? The copper star will make a substantial difference, but I got over 1,300 lumens on my Convoy C8 at 4.2A.
Just got mine today and I’m impressed. This thing is super bright, brightest hotspot I have seen on any light so far. Good build quality, feels like it weighs twice as much as my KD C8. One question, I was using a 2600 mah AW protected cell, would a high drain battery make this light brighter? I can’t measure the current draw because my crap multimeter only measures up to 1 amp.
