We've had some projects that have been in progress for a long while now, I'll see what I can do when it comes to the bare emitters. Give me about a week to wrap up some things :)
These puppies arrived in the weekend:
XM-L2 T5 5A3 (80+ CRI) on 16mm Noctigon 6,89$
XM-L2 T5 5A3 (80+ CRI) on 20mm Noctigon 6,89$
Like Hank say, nice option for those who loved the 5D2.
And like I say about such emitters, nice option for tint mixing since these are below BBL (most other emitters and de-domed emitters are/end up above)
Ill e-mail Hank and make him double check the specs though. T5 bin and 80+ CRI??
I placed an order anyway. :)
Hank as already confirmed that the specs on the above emitter are correct.
Which should make the emitter AWESOME!
Well, that was quick.
Illumination supply had a small batch of NVSL219B R85 D220 (92 CRI, 4500k) but I guess it sold out since the listing is gone. Marked it as out of stock in the led database.
Thanks for making it available in bare emitters.
Quick indeed.. Too quick..
Emitters from Mountain Electronics have been added to the spreadsheet. Thanks for adding them RMM! (there are no links though) Feel free to contribute more, and update/post in this thread too. :)
For all the people in the US it must be great having another good source for lots of nice emitters. Its also nice for international buyers since shipping is generally fast. I have god experience with this seller, and I am sure many US buyers have too. :)
IOS have gotten some sweet XP-G2s.
XP-G2 R4 5A2 with 70+ CRI (not 70 CRI typical which is normal).
He did put link to the product in the spot for the store link on each item. I usually do that too. Its a convenient spot.
=HYPERLINK ( “http://www.mtnelectronics.com/opencart/index.php?route=product/product&path=60_62&product_id=86”,“Mountain Electronics” )
I added the links at the end.
Helios-, you are correct. :)
Just saw on the ebay lck led store that they sell xpe2 in 1D tint, but also in 7C tint (Q3), on a 16mm board, $2.21 , have not seen that one before. By the way, the edit: 20mm xp Sinkpad goes there for $20.25 for a sheet of 15.
Would be nice if lck led would list the tint on their actual website. XP-E2 on ebay
Sort of hesitant to put ebay links into the LED database since the links expire if the listing isn’t endlessly renewed. Thoughts?
“Q4” in title, Q3 in discription. :weary:
~ edit ~
Is LCK-LED reliable with bin & tints?
$20.25 for the sinkpads? I’m seeing 15pcs Sinkpad XP 20mm for $22.50. Still the best quantity discount on copper stars without a dielectric layer.
LCK-LED ebay listing
15pcs Sinkpad XP 20mm - $22.50 ($1.50 each)
XP-E2 Q3 7C (3000k) 16mm - $2.50
XP-E2 R3 1C (6500k) 16mm - $2.45
These XP-E2 tints might also be available on 14mm and 20mm stars at LCK-LED.com only the tint isn’t listed on the page.
LCK-LED carries 16mm, 20mm sinkpads in XP, XM on their site. You could inquire about their quantity discounts if you need something other then the XP 20mm that is currently in their ebay store.
Dunno what happened, I suppose they did not change the price since this afternoon, so I must have quoted it wrong, the ebay-site also says: 3 sold, 2 left.
wow, that was fast!
From Fasttech
XM-L2 T6 4D, 4,98$ and upwards (mcpcb size: bare emitter/12/16/20/25/32)
XM-L2 T5 5A2, 4,98$ and upwards (mcpcb size: bare emitter/12/14/16/25/32)
XM-L2 in 4D tint is an emitter I look forward to try. :)
When it comes to 5A2, personally Id rather stick to the 5A3 from IOS which is 80+ CRI and can be bought mounted on Noctigon. But its nice having options. :)
http://www.maritex.com.pl/en/shop/products/ggid/18074
Here there is so much stuff!
MT-G2 4000K
MCPCB 4x XB-D
XP-E2 Q4 7A3 O_O
Unfortunately, we need at least € 50 minimum order!
Nichia CRI92 NVSL219B-E R85 B220 LED
Is listed in DB as D200 but KD tries to sell as B220 so lets say it’s supposed to be D220?
Not that I believe it.
KD may have changed the bin as I recall it being just below Illumination Supply’s 219B R85 D220.
Can be, I just found it there is a new one and also on KD.
Have enough IS Nichias and Carclo lenses. But these random KD Nichias can be nice for the lowest budget mods.
If it’s only D200 and higher L or M voltage, it’s just like good old IS 219A B10 L.
