Will have to try one of those next :) Just wanted you to know that this has been the best one so far (I've tried a few others). I have used Yiboyuan phone battery chargers for years with my Droid X and now HTC Rezound, no problems with them whatsoever.
FYI:
More small flashlight holsters in stock, along with the butterfly style XM-L emitter spacers.
About the charger, no it isn't the most eloquent solution, but it works great and has been reliable. Besides, this is budget light forum, right? I have been testing it all week long to make sure that it was good to go before announcing it here. None of the other solutions I've tried or looked at up until this were going to be cheap enough to be worth it, to me at least.
Not as easy as that, emitter hole will have to be opened up. I will be doing this in the next couple of weeks, have a project going on to compare apples to apples in a Cree Trifecta using Convoy C8’s as the hosts.
Hey! Been super busy with all the orders and holiday events these past few days, but here are some updates (are either currently up on the site, or will be there in a few hours):
New:
Bare XM-L2 1A LEDs
Bare XM-L2 1D LEDs
Bare XP-G2 R5 3C LEDs
Bare XP-G2 R4 5A1 LEDs (for you warm tint afficionados!)
14mm XM-L2 3C (aluminum star)
XM-L2 T3 7A3 on 16mm and 20mm Noctigon
P60 Bare Dropins - Orange Peel & Smooth Reflectors
20, 24, & 26 AWG Silicone Wire
Arctic Alumina Thermal Compound (14g)
Convoy S3-like host (identical except it doesn't say "Convoy")
Restock:
20mm & 42mm AR Lens
qlite drivers
Plastic 3M Emitter Insulating Gaskets - XP and XM
XP-E2 R4 1C on 16mm Noctigon
XM-L2 T6 3C on 16mm & 20mm Noctigon
XM-L2 T4 5B1 on 16mm & 20mm Noctigon
Probably some other stuff I'm forgetting right now, but that's most of it!
when clicking on the top tab - "Flashlight Hosts" your flashlight hosts are hidden. Some people new to your site might not even see that you have light hosts.
You might consider moving your flashlight hosts under "Flashlights" tab.
and move empty P60 drop-ins under "Components".
Maybe on your Silicone Wire page add an Ampacity Chart like (wiki), since this is one of the more important specs when choosing AWG. ppl should know... what is the recommended max current for a certain wire size.
After-all the site is quickly becoming a modder's haven.
Site’s working fine over here MRT, hosts show as well as the empty drop-ins. Click hosts in the top row for the hosts, click the drop down menu for P-60 drop-ins to get the empty shells.
And for what it’s worth, the amperage capability of a wire is going to vary according to it’s type of copper, number of strands and various other factors. Wiki’s description is way on the safe side, in my humble opinion. Tenergy Silicone 22ga wire is easily capable of more than double that chart. Or at least, it’s giving me siginificantly higher numbers in my lights.
And as a caution, there are just some things you don’t want to buy the budget versions of. I just received 22 ga silicone coated wire from a vendor I had not purchased it from previously. The silicone is so thick on the 22 ga that it’s bigger than Tenergy 20ga and won’t fit in my smaller lights at all. Sometimes it’s best to stick with the known name brand.
I think he’s trying to say it’s different from the other drop downs which when clicked go to a webpage with the two options as links. Confused me for a sec when the hosts didn’t show up under the host tab.
Regarding the new 20, 24, and 26 gauge silicone wire: it isn't as nice as the 18 and 22 gauge that I have. The strand count isn't as high and it is a bit thicker than it could be, but it is less expensive and you still get the benefit of the silicone sheathing. I will have to work on adding the OD to each of them.
I'm still trying to decide how I want to categorize the new additions. The current layout isn't permanent, don't worry too much
