X60vn in hand and tested - its a true monster!
32 posts / 0 new
rdrfronty
Guys I just couldn’t pass up this monster that Vinh just released. Its big and its expensive, but by golly its a beast of a light!
It is really impressive over all. The light looks good, appears to be pretty good quality, and has a pretty nice UI. Has the clicky in the back and true variable ring for power levels. And it even has a magnetic charging port back by the clicky. And I must comment the magnet in my example holds very well. The light is pretty big, but about 2” shorter than my SR90 and it’s noticeably lighter than the SR90 and BTU.
Now for the good stuff. My numbers -
Low – 7.5 lumens
Level 2 – 574 lumens (level after low)
Max – 6430 lumens (at 30 seconds)
Throw – 433Kcd (calculated at 15m)
That’s very impressive. Even more than I expected. We’re looking at 1286 lumens per dedomed XML2. I’m thinking this light might be tweaked to maybe 4.5A or so? Vinh estimates he bumps them to about 4a. Don’t know, but I like it. And thanks to the 6 cells, the light will still have reasonable runtime. I haven’t run it for too long of period yet, but I only felt it getting mildly warm. As a interesting and kinda scary fact, the sitting voltage I just measured out of this lights battery carrier – 25.2v – yikes!
Oh, for those of you not familiar with this light, this version has dedomed 6500k XML2 U2’s. And it comes with a nice carry case along with car charging adapter, shoulder strap, AND a cool bonus – 6ea 2600mah protected 18650’s. Supbeam brand, so who knows, but they appear to handle this beast just fine.
Man the X60vn just lights up everything in front of you. Awesome throw and awesome flood. Best of both worlds. And no waiting for warmup (hint HID). Just instant wall of light wide and far!!!! And to think this monster even has a 7.5 lumen level that you can use for creeping around your house at night.
For some comparison sakes how well this light stacks up, here is a listing of the X60vn along with a few other powerful lights I own. All tested with the same lightbox and meter, and same testing methods. All lumen numbers are taken at 30 seconds. And all Kcd numbers are the highest repeatable number reached after about 15 seconds. These serious throwers I always test at 15m and calculate back.
Here -
TN31mb – 741 lumens & 414Kcd (4.0A?)
K40vn – 1625 lumens & 393Kcd (6.5A)
TN31vn – 1740 lumens & 495Kcd (6.5A)
X40vn – 3045 lumens & 158kcd (4.0A)
BTU – 4260 lumens & 477Kcd (5.5-6.0A)
FF4 – 7010 lumens & 430Kcd (60wt)
X60vn 6430 lumens & 433Kcd (4-4.5A?)
Well no beam shots tonite. That will have to wait for the next clear weekend. Here are a couple shots of the X60vn with some of my other serious lights.
leaftye
Last seen: 12 hours 51 min ago
I'm thinking about getting a beast from v54.  $365 is a lot though, and I really should get a balance charger to go along with it.  I may miss out on batch 2, so hopefully he does another batch.  I'd almost certainly keep the domes on.
The low mode should be lower.
ryansoh3
ryansoh3's picture
Nice to hear some positive info on the X60 after so much hate.
Looking forward to beamshots! Smile
BLF ≠ B-grade Flashlight Forum
rdrfronty
leaftye wrote:
I’m thinking about getting a beast from v54.  $365 is a lot though, and I really should get a balance charger to go along with it.  I may miss out on batch 2, so hopefully he does another batch.  I’d almost certainly keep the domes on.
I do agree its expensive. More than I should have spent. I got in the first batch and was a little cheaper at $336, but still pretty bad. I can only justify the cost possibly by how dominate it is in performance. I mean this thing has almost as much throw as my Supershocker, but has 2200 more lumens. It’s not that far from a TN31 running at 6.5a. And it has, what – 4700 more lumens than it does. There really is no other led that can truly compete with it. Not even modded. Not even a modded TRJ18. And the X60vn does this while running at a reasonable 4-4.5a. Stock it has a 2hr runtime on high, but even at this level it will likely do well over an hour. And yeah its suppose to kick down at some point. But that “lower” level will still be about 5000 lumens. And of course you can still kick it back up if you want.
As for leaving the domes on, I thought about doing that too. But now seeing the serious flood and wall of light the X60vn puts out even dedomed, I just don’t think keeping the domes on will benefit enough to counter what I would guess to be a 200k+ loss in throw. It would still be very impressive in that setup too though.
blueb8llz
Last seen: 2 hours 56 min ago
congrats on this purchase! i need to see this and the super shocker going toe to toe
leaftye
rdrfronty wrote:
I do agree its expensive. More than I should have spent. I got in the first batch and was a little cheaper at $336, but still pretty bad. I can only justify the cost possibly by how dominate it is in performance. I mean this thing has almost as much throw as my Supershocker, but has 2200 more lumens. It's not that far from a TN31 running at 6.5a. And it has, what - 4700 more lumens than it does. There really is no other led that can truly compete with it. Not even modded. Not even a modded TRJ18. And the X60vn does this while running at a reasonable 4-4.5a. Stock it has a 2hr runtime on high, but even at this level it will likely do well over an hour. And yeah its suppose to kick down at some point. But that "lower" level will still be about 5000 lumens. And of course you can still kick it back up if you want. As for leaving the domes on, I thought about doing that too. But now seeing the serious flood and wall of light the X60vn puts out even dedomed, I just don't think keeping the domes on will benefit enough to counter what I would guess to be a 200k+ loss in throw. It would still be very impressive in that setup too though.
I figure I can dedome later if I really want more throw.  I'd probably upgrade the emitters of the XM-L continues improving anyway, which is a great time to try something different.  If I do get this light, I'll also get a BTU that's dedomed. V54 gets really good prices on the BTU, so I might have him mod it too.  It's kind of depressing.  I want to do it myself, but there's not much point if it costs about the same to have the work done for me.
JohnnyMac
JohnnyMac's picture
Last seen: 1 week 14 hours ago
Nice!  That X60vn is bright as hell and sweet looking to boot!  I'm envious. Silly
MRsDNF
MRsDNF's picture
Last seen: 2 months 6 days ago
Wow. Cant wait for the night shots. Thanks for sharing.
18sixfifty
18sixfifty's picture
Last seen: 2 years 11 months ago
Wow that is quite the light. Congrats on owning that beast.
I’m a junky, I mod lights so I can sell lights so I can buy more light to mod so I can sell lights to buy more lights to mod.
RaceR86
RaceR86's picture
Last seen: 6 years 7 months ago
DAT big awesome 5x XM-L2 reflector..  Love
Sick light.
I hope there will be a budget clone soon.  0:)
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
leaftye
Sick light.
I could swear I've seen a 6x18650 that was similar to this with multiple emitters and side clickie...
http://budgetlightforum.com/node/26701
Found it.  Not a side clickie.  http://www.shenzhen-wholesale.com/12XT6-CREE-T6-5-modes-super-Bright-Aluminum-Alloy-LED-Flashlight_sku9979.html
rdrfronty
leaftye wrote:
Sick light.
I could swear I’ve seen a 6×18650 that was similar to this with multiple emitters and side clickie…
That 2nd link is an interesting light. Looks pretty good. If you can put one of those beast drivers in it, I think it would be a neater light than the TRJ18. I’m sure those 12 LEDs would heat up pretty quick though with the 90mm head. Would be an impressive flooder if not driven too hard.
RaceR86
RaceR86's picture
Thanks for the suggestion leaftye. I am aware of those lights.
I already have a sick modified multiemitter light.  Form factor is not what I find interesting. The large 5 emitter reflector is what I am drooling over. Smile
FlashPilot
FlashPilot's picture
Last seen: 1 day 5 hours ago
Thanks for the mini-review. Im sure you’re very proud of your light and have every reasons to be. Just the fact that the host isnt glued in this category of light makes it that much more appealing. If this were a larger & deeper reflectored light (such as an upscaled BTU reflector) Id bite in a heartbeat and gladly kick out the $. Of course everything is a compromise, and this light would easily serve a great many needs while satisfying expectations.
Group buy anyone?
Im looking forward to your beam shot comparisons.
rdrfronty
Vinh says the X60 actually comes stock with a copper pill that the LEDs sit on. He basically took it out, sanded the surface smoother, reapplied the xml2’s on copper Sinkpads onto this copper pill. Of course dedomed. He then did a resistor mod to bump it from appx 3A stock to its current 4-4.5A range. He then did wick mods on all the springs, touched up any connects needed and replaced all the main wires. He said stock it was setup pretty nice. But with him boosting the amps he wanted everything bumped along with it.
unknown00101
That’s the first stock light I’ve heard of running on a copper pill, interesting. Though running it on copper doesn’t really make much sense with the conservative 3A drive.
FlashPilot
It does make you wonder since many people seem to equate a brass pill as one made of copper.
leaftye
unknown00101 wrote:
rdrfronty wrote:
Vinh says the X60 actually comes stock with a copper pill that the LEDs sit on. He basically took it out, sanded the surface smoother, reapplied the xml2's on copper Sinkpads onto this copper pill. Of course dedomed. He then did a resistor mod to bump it from appx 3A stock to its current 4-4.5A range. He then did wick mods on all the springs, touched up any connects needed and replaced all the main wires. He said stock it was setup pretty nice. But with him boosting the amps he wanted everything bumped along with it.
That's the first stock light I've heard of running on a copper pill, interesting. Though running it on copper doesn't really make much sense with the conservative 3A drive.
It does when it costs 300,000 cents! I like that they've improved the headroom for this like.  The Thrunite TN-32 also has a copper pill, except the copper extends to the exterior where it can have the greatest effect.
leaftye
Still no beam shots?
rdrfronty
Sorry, but no. Way too difficult for me to do during the work week. I live in the city during the week, but head to family country house on weekends. This one, and many of my lights are too powerful to use around town without attraction too much attention.
In fact, I had my X60vn out shining across a field close to the house this past weekend. Maybe 300m away at a treeline. There are houses perhaps 20deg or so away from where I was shining (same distance away). Only had it on for perhaps 10 seconds.
Went back about 15min later with a few other lights to try in comparion to the X60vn. And guess what I find – squad car sitting right in front of the treeline I was shooting at, sitting in the dark, faced my direction. Had to get binoculars out to make sure it was a cop. No mistaking the lightbar on top.
So no more playing in my neighborhood with the powerful lights.
If the weather cooperates this weekend I’ll get some shots done. Its suppose to be a decent chance of rain, so we’ll see how it plays out.
Any particular lights you want to see it compared too?
DENGOH
DENGOH's picture
Last seen: 3 weeks 3 hours ago
Wow, this light is really monster light. Throwing 6400 lumens for such long distance is incredible.
cool i'll see you when you get there
hyde
They called the cops on you for using a flashlight…
IN TEXAS?!?
Dear god, here in Boston I would be talking to the bomb squad like my name was Tsarnaev.
blueb8llz
the main comparison light i would like to see is vs the tom e super shocker please
bibihang
bibihang's picture
Last seen: 15 hours 47 min ago
+1
MountainKing
I don’t have 18650 cells as I am very nervous running those things. I’d imagine I’d crap my pants if I hold one of those 6×18650 cell lights when they are on turbo.
The cost is high too but I guess if you have a real need for this kind of monster (Maybe SAR, living in huge farms, forests etc, other uses), that $365 would be a reasonable and useful investment.
Now for only taking beamshots or shelf queens, this has little interest unless someone is kind of a ‘collector’ Wink
Just my 0.02 lumens!
Never ever forget and forgive. Niwal**er new kid on the block trying to act tough.
http://budgetlightforum.com/node/24847
Do not support this brand.
DINODIRECTSCAM COMPANY. DO NOT BUY
http://budgetlightforum.com/node/11324?page=2#comment-254983
rdrfronty
I tried to do some beamshots last night, but no luck. It had rained all afternoon and had cleared up – but fog showed up in the evening really bad. The lights were fun to play with in the fog, but it would suck for comparison beamshots. I will try again Christmas Eve if I can.
The plan is a multi-emitter shoot out. Between brother and I we have – x60vn, x40vn, BTU-5.5A dedome, BTU-5A domed, BTU-stock driver, M6-3500 lumens, King-stock, King-2600 lumens, Kung-3100 lumens, SP03-dedomed, TK75-stock, Terminator-3500 lumens, TRJ12-beast driver. That’s the planned lineup as soon as I can and weather permits.
As for using the lights, shelf queens, etc. – I rarely NEED to use any of these big lights. I do use a variety of smaller EDC’s on a regular bases. But none of these big lights ever see true flashlight duty.
However, none of my flashlights are shelf queens. They might be not used for work, but they are all used regularly for entertainment and as a cool hobby. For me that is their intended use when purchasing them. I think its obvious from how much I’m on here doing lumen or lux measurements, doing beamshots & etc., that I use all my lights. I’ve actually made 1300 mile round trips for the sole reason of having a cool place to try them out. Kinda nutty, possibly wasteful to some, but I enjoy doing it.
And I do actually have a pretty limited budget. It might not sound like it from some lights I’m regularly buying. But I would rather spend my spare cash on interesting lights, rather than partying, going out to dinner regularly, or other typical expenditures.
I pay my bills, take care of my family, and plan for the future. Anything else left tends to go for my “flashlight fund”.
Anyway, for law enforcement, S & R, etc., I feel this light would make an excellent choice. You get the performance (power and runtime) of high end HID’s, get the instant LED on and off, all at a very reasonable cost when all is considered. Well over 6000 lumens and 1300 meters throw, all regulated and running on 6 included 18650 protected cells, at just over $300 isn’t really a bad deal. Especially for agency’s, police departments, etc.
unknown00101
I’d love to see beamshots of that lineup.
Shelf queens or not, I love seeing the crazy results people can get out of these higher dollar lights.
$400 expenditure on a hobby every 2-3 months is still cheaper than a lot of other hobbies.
MountainKing
@rdrfronty: My thoughts were directed only at myself Wink I’m reasoning with myself here bro!
rdrfronty
I understand and no offense was taken. I think sometimes I make these posts like above to try to convince myself I have a good reasons for blowing a wad of dough.
I’m divorced now (no, not because this hobby), so I gotta get my jollies some how Smile
leaftye
Get any beamshots?
rdrfronty
leaftye wrote:
Get any beamshots?
I’ve done one quick set sofar with other multi led lights. The thread -
http://budgetlightforum.com/node/27306#node-27306
