i suspect they just want to use up their xm-l chips
there are not enough batteries to run this thing to its full potential (assuming that wonāt go poof when you hit the switch)
Now mod this to run 4 - 5 amps to each emitter on a massive copper plate hybrid with CPU liquid cooling with a remote battery pack, maybe a 1000 CCA (Cold Cranking Amp) Deep Cycle RV battery mounted in a back pack. Might make a good flooder. J)
now your talking, but getting maximum possible output would cost a lot of money, xm-l2 on sinkpad/noctigon, i wish companies would start making high Ah NiMH, but any battery that can put out the amps would get well over 20,000 lumens with CPU liquid cooling!
You could buy a Tesla and remove the fuse from the cigarette lighter : :bigsmile:
ā¦and what exactly would you want to āilluminateā with that kind of flood power? Neighbourās Backyard? and one more thingā¦what is wrong with ducttaping 18 convoys S2 āin paralellāā¦ J) at least it will be slightly cheaperā¦
More Lumens the better ! i do alot of night Geocaching, backcountry camping, canoeing, boating, biking, etc. and have a high diet of lumens per day. :bigsmile:
These multi-emitter lights are getting out of hand! When will to many be too much? One of us needs to go a head and build a 100 emitter light. :bigsmile: Iām happy with my 12 emitter lights.
