Test/Review of Tensai D TR-C8000 8000mAh (White)
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 3 hours 33 min ago
DSC_3607
Official specifications:
  • Model: TR-C8000
  • Manufacturer: TENSAI
  • Size: D , LR20
  • Chemistry: NiMH (Nickel Metal Hydride)
  • Nominal Voltage: 1.2V
  • Capacity: Minimum: 8000mA, Typical: 8050mA, When discharged at 0.2C to 1.0V at 20°C
  • Fast Charge: up to 4000mA
  • Service Life: >500 cycles
  • Internal Resistance: Diameter (mm): 33
  • Height (mm): 61.5
  • Weight: 155g
Tensai%20D%20TR-C8000%208000mAh%20(White)-info
Maximum temperature raise at different discharge currents: 1A:+0,0°C, 2A:+0,2°C, 3A:+1,4°C, 5A:+4,8°C, 7A:+8,2°C, 10A:+11,9°C
A LSD (Low self discharge) D cell.
DSC_3606
DSC_3608 DSC_3609
DSC_3610
DSC_3611
DSC_3612
Tensai%20D%20TR-C8000%208000mAh%20(White)-Capacity
The cell can handle a 10A load and do have the rated capacity, even at high load, but there is also a capacity different between the cells.
Tensai%20D%20TR-C8000%208000mAh%20(White)-CapacityTime
Tensai%20D%20TR-C8000%208000mAh%20(White)-CapacityTimeHours
Tensai%20D%20TR-C8000%208000mAh%20(White)-Energy
Tensai%20D%20TR-C8000%208000mAh%20(White)-PowerLoadTime
Tensai%20D%20TR-C8000%208000mAh%20(White)-CurrentTest
Tensai%20D%20TR-C8000%208000mAh%20(White)-Charge
Conclusion
The cells look acceptable and the 8Ah capacity in a LSD D cells is good.
Notes and links
I do not test above 10A because, my current equipment cannot handle 20A below 1.2 volt. 10A at 0.9 volt works fine.
The batteries was supplied by ENERDan for review.
RaceR86
RaceR86's picture
Last seen: 5 years 10 months ago
Once again, thanks for the review! Smile
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
Bort
Bort's picture
Last seen: 7 hours 50 min ago
very interesting Smile
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
