H4 MT-G2 Headlight
16 posts / 0 new
zeremefico
zeremefico's picture
Last seen: 3 hours 45 min ago
H4 MT-G2 Headlight
ebay link
I like the idea but the build doesn’t look very quality to me.
It will have a great tint though unlike the bluish xenon aftermarket lights.
I would like to see the driver (there is an external ballast) & the working current, any volunteers?
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
Edited by: zeremefico on 12/25/2013 - 13:10
light junkie
light junkie's picture
Last seen: 1 year 3 months ago
That would be interesting to see!
Lj
MRTdiver
MRTdiver's picture
Last seen: 8 years 1 month ago
For that heatsink you would have to have the available space behind the light.
Funny since I just changed headlight bulbs today.   put in the Sylvania Silverstar ULTRA. (eBay)
nothing special - same wattage, different tint - more cool white.
נֵר־לְרַגְלִ֥י דְבָרֶ֑ךָ וְ֝אֹ֗ור לִנְתִיבָתִֽי   (Psa 119:105)
edeekeos
edeekeos's picture
Last seen: 1 month 1 day ago
wow, would love to see these in action. bet the tint would be nice.
I still think 55w 4500K HID’s would have better output and color rendition though.
I am still on the search for a few things:
Solarforce L2-S12 tailcap
Solarforce L2-S11 tailcap
Solarforce A001 Head
Solarforce Y2 Zoomable Flashlight
Solarforce L2E Flashlight
Solarforce P1 Yellow
Solarforce K3 TurboHead
zeremefico
Output and reliability sure but the MT-G2’s tint is hard to find elsewhere.
My YouTube channel
K40M F16
kwarwick
Last seen: 2 months 3 days ago
Even if you have the room to fit them, I can’t imagine the heat sink fans would last in an automotive environment.
DayLighter
DayLighter's picture
Last seen: 5 years 8 months ago
the beam output produce awful illumination for the road.. the darkness in the middle? it is where the light should be Flat Stare
and the HID 55 watts these day can be had for about $50 why but these ?
doesn’t make sense economically nor practical
The only way to do a great work is to love what you do.
Bort
Bort's picture
Last seen: 9 hours 24 min ago
Its a nice idea, but i doubt it would work, perhaps 3 XM-L with overlap would function better (and cheaper), but the heat will likely cause damage being in the “wrong” place, and you can’t count on that fan, its quality is likely bad and even if its the best fan on earth there is no failsafe
Also i doubt this would be legal (good and bad, prevents innovation but also prevents problems)
The Journal of Alternative Facts
"It is critical that there is a credible academic source for the growing and important discipline of Alternative Facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists."
edeekeos
edeekeos's picture
I could possibly see these as a secondary light source, maybe something like fog lights. 6k+ lumens worth of fog light wouldn’t be to shabby.
FlashPilot
FlashPilot's picture
Last seen: 29 min 42 sec ago
Such a feeble design attempt, and certainly made me laugh a few times. At least they didnt lie about the awful beam pattern, which is inevitable in that arrangement.
DBSAR
DBSAR's picture
Last seen: 11 min 1 sec ago
This would be better if they used a centeral “Heat Pipe” style heatsink and a passive cooler fins without that un-reliable fan idea. Also with a design that used the two MT-G2’s and an XM-L in the center facing forward to lessen that dark spot that would occur with some reflector designs.
Still regardless.. LED’s have come a long way, but not yet perfected enough in a design to be able to directly replace automotive style bulbs to work in standard original OEM housings & reflectors designed for Halogen Incans or HIDs, ( which have almost a 360 degree emitting range versus the flat, almost omni-directional LED emitting pattern.
Bort
Bort's picture
I figure unless Cree decides to design a bulb to replace halogen in the halogen designed housing of todays cars (which won’t happen for non technical reasons) we will never have one that can retrofit directly.
I look forward to the beter cri and higher lm/w LEDs we will have by then
electromage
electromage's picture
There’s no way these can work correctly. Car lamps are designed to have a single point source to focus, if you separate it like that there’s no way you’ll get a useful beam.
Aside from that, the heat sink is a joke. There’s a reason that car manufacturers are spending so much money developing LED systems, they have to function reliably in one of the toughest environments for a machine with vibration, huge temperature variations, water spray, dust, electrical spikes and sags… Even when designed properly I still see Porche and Audi headlamps and DRLs out.
CPF: electromage
Reddit: electromage
VrestoTaylor
VrestoTaylor's picture
Last seen: 3 hours 25 min ago
anyone saw this?
http://www.acebeam.com/acebeam-headlight-h1#.VRm_W45VmUQ
when this should be out???
EDC- Wurkkos TS22 XHP70 nw, Sofirn SC32 XHP50 nw, WildTrail WT3M
Headlamp- Thrunite TH30
DBSAR
DBSAR's picture
vresto wrote:
anyone saw this? http://www.acebeam.com/acebeam-headlight-h1#.VRm_W45VmUQ when this should be out???
That is a different “Headlight” than the OP Automotive headlight driving lights they were referring to. That may be a nice light though that is designed to be worn on your head (with a head band or headlight strap assembly)
alpg88
Last seen: 2 weeks 1 day ago
i had h11 just like that with cxa leds, my impression, beam sucks, worst than oem halogen in projector headlight, fans vibrate, i could feel my headlights vibrate when i put my hand on them. the heatsink got too hot too touch, the fins got cloged with dust\dirt, and fan bacame useless. afetr few days one driver started to flicker.
very much useless thing, imo
