Anyone owns the XinTD X3 from Wallbuys/Banggood?
Hi, thanks for your input. So is the lens AR coated as well? Also did you notice any difference between your version with the IOS one?
Thank you!
How does it compare to the HD2010?
Gj I did not see that light on mtnelectronics? Just 3 C8’s
Just got mine from Banggood, and I'm surely impressed!!!! Especially for $35...
I mean build quality wise.. No sharp edges, and couldn't see any flaws in its anodization. Nice color as well.
It’s fast for you! I also have ordered the X3 from Banggood with $31 after discounted with coupon code, but they only shipped out at 23 December due to out of stock (it appeared to be “in stock” when I ordered). :expressionless:
Anyway if Banggood is really good then I should receive the light within the standard-14-days, which is by next week or around so.
It is beautiful, kind of a Gunmetal Gray, lubed threads, deep reflector, kind of a cheap aa battery holder, a thick plastic 18650 adapter, no 26650 adapter, but one could easily improvise one with PVC. Ok, I loaded mine with a Powerizer 26650, draws 3.2 amps at the tail. I have a LG 18650, draws about the same amps. Haven’t tried the Eneloops yet, Yes, it is very bright and a definite thrower.
I ordered 2 from banggood on dec 7 haven’t seen hide nor hair of them but they sound pretty good , can’t hardly wait
My two x3’s came in today, yea! Wow they are a gorgeous light . The only batteries I have at the moment are tenergy aa and the 3aa battery carrier is crap but it does work ok . Waiting on some 18650 but am happy to see them arrive .
Was about to order this until I seen this post. No sharp edges = No deal!
So you prefer sharp edges?
Definitely do! I got this instead so I could attack Tigers in the Jungle, or maybe crackheads too!
http://dx.com/p/godfire-x-06-cree-xr-e-q5-1-mode-250lm-attack-head-white-flashlight-black-16340-cr123a-276759
I think you mean the spiky bezel, not the sharp edges that left by poor machining.
Yes, I really don't understand people like poor machining that can even cut your skin.. that's what I meant by No sharp edges=poor machining.
Yes, I really don't understand people like poor machining that can even cut your skin.. that's what I meant by No sharp edges.. Sharp edges=poor machining.
The battery carrier from ios is far better imo :)
Yes I did actually notice that, but considering the significant price difference I ended up ordered with Banggood anyway lol.
I paid 34 for one with T6 4C.... a good price I would say..
Don't care much for the battery carrier.
i guess the xintd x3 that wallbuys sells should be the same banggood sells? (hard to know, but flimsy 3AA carrier, 3/5-modes, no moonlight mode should apply to both?)
i ordered 2 from wallbuys group buy a couple of months ago (i have received one, the other one seems to be lost in china post since 17 november…)
i have tried the one i’ve received, and when i use 3x GP Recyko batteries, and use high, after a while the flashlight ramps up and down, is that a low voltage warning? it happened when the batteries where quite fresh though, and IIRC 4.02 V resting voltage over the battery carrier.
I am thinking about gifting one of the flashlights as it should be great for non li-ion people, but i’m unsure if i have a defective flashlight, or if it can’t be used on high with nimh’s?
I notice FT also sell the same one with Banggood. at least the same battery carrier.
can anybody post a little bit update after couple months usage of X3 from Banggood one?
I’m considering this one over Starry Light…
thanks…
I’ve bought X3 from BG… What would you like to know?
Quality wise…it’s excellent! Threads were a bit dry on arrival but I lubed them and modded this weekend(replaced driver for Qlite with added 4x7135 380mA and changed led to T5-5A3) and I couldn’t be happier.
