I don’t want manufactures or the downstream distributors/vendors to think they can get away with misrepresentation. The language barrier is a weak excuse. I’m certain they have a firm grasp of payment systems despite language barriers. In return for the robust profit margins they receive we should have assurance of product integrity!
@cat eyes: While I partially agree with you, your posts are very hard to read.. and make you seem less smart than you might be.
HKJ posted his review of KP 14500 on 31.03.2012, thats not far from 2 years, is it?
In the other thread, you posted that you got 14500s labelled "cell and IC made in Japan" but found a blue cell, and you still think it was just a mistake?
Since its happened with 14500 and 18500 over an extended time period who knows what keeppower batteries are affected. Get some 18650 shrink wrap, buy the WB 3400s & just check that its not labeled wrong. You can do shrink wrap with a hair dryer or a lighter even.
I have perhaps 20-25 Keeppower 3400mah 18650 cells. While I don’t know for certain every cell is legit and not rebranded, I do know they are all good cells. All have been tested in lights countless times. If it was a rebranded ultrafire or such, I would have found out by now. Most of my high power lights need quality cells to operate properly, and all of my Keeppower 18650’s deliver the power needed.
I can’t say much about their other battery sizes since I little experience with them.
Personally I would check. I would want to be sure of what I really had. Even with 25 batteries I would check them.
Shrinkwrap from FT is cheap. You could the reaply the keeppower label under clear shrinkwrap. If needed, heating the label with a hair dryer should soften the glue to help peel it off the original wrap.
I think it is hard to trust any of them. I only say this due to the fact that labels for various manufacturers are available to re wrap a cell. Are the metal barrels of the cells from Panny or Sanyo marked under the main wrapper? if not how do you really know who’s battery it is?
Peel part of the label back, cut a hole or flap and press the label back down after you check. From my own limited knowledge, green is Panasonic, red is Sanyo and blue is unknown. No guarantee green or red aren’t fake but probably not.
I just ordered the clear shrink from FastTech so I should have it by March.
Here’s the label back on. It would look better if I cut a flap and was more careful.
With 18650s keeppower makes batteries using a few different cells. Cut a hole, see light green & it could still be mislabeled.
With 14500s labeled as sanyo it seems to be either red (correct) or blue.
I posted the below in reply to a PM from an aggrieved member here and feel that it is worth sharing here, both for other members perspective, for those affected such as unfair associations IS have experienced and for Keeppower to aid in understanding how damaged their “baby” as they put it, currently is.
Keeppower, it’s time for public, sincere and remorseful actions.
If you fail to demonstrate atonement in your actions, people simply will not forgive the prior actions that resulted in this mess, be they nefarious or devious.
Enough with the hollow words, back it up with actions that show your intent and that enable the rebuilding of your “baby”.
IS, it is unfair that you have been associated with the actions of Keeppower, which is why I suggest Keeppower conduct a group buy/introductory deal for us end users through you and to reward your upstanding name in this and no doubt other communities, naturally of course, only if you’re interested in still dealing with Keeppower.
Aren’t they green wrapped by Panasonic before KeepPower gets them?
I don’t know about blue Sanyos. Blue is a common color for crappy generic batteries. Do they have the same raised lettering as the red Sanyos? That’s not easy to duplicate.
I meant panasonic 3400 isn’t the only light green cell that keeppower uses in their 18650s. It could also be a 3100 or 2900 cell. Perhaps other cells. With 18650s you really need to see the name on the cell not just its color.
With 14500 the color is enough to check it. If you cut a hole you will either see red (correct color for sanyo) or blue (not sanyo).
