Test/Review of Tensai C TR-C4000 4000mAh (White)
Official specifications:
  • Model: TR-C4000
  • Manufacturer: TENSAI
  • Size: C , LR14
  • Chemistry: NiMH (Nickel Metal Hydride)
  • Nominal Voltage: 1.2V
  • Capacity: Minimum: 4000mA, Typical: 4050mA, When discharged at 0.2C to 1.0V at 20°C
  • Fast Charge: up to 2000mA
  • Service Life: >500 cycles
  • Internal Resistance: <30mOhm (upon fully charged)
  • Diameter (mm): 26
  • Height (mm): 50
  • Weight: 80g
Maximum temperature raise at different discharge currents: 1A:+0,7°C, 2A:+2,0°C, 3A:+3,6°C, 5A:+7,7°C, 7A:+12,3°C, 10A:+17,5°C
A C sized LSD cell, that has more than specified capacity.
The cells has a good capacity match all the way up to 10A, but they are pressed at 10A.
All the mess between 12A and 14A is my setup that hits its voltage/current limit.
Conclusion
This looks like a good NiMH battery.
Notes and links
The batteries was supplied by ENERDan for review.
Thank you HKJ for the nice review. Happy new year!
