My God! Would you look at the price? I almost bought it till I got to that.
Sexy light!
Sexy light!
Minute, expensive and for me the deal breaker is the non-standard cell in it. Those are going to be hard to find.
cannot see tritium in the tail. It is expensive. But it is Ti and tritium…
Fun little light, no real reflector, the picture shows old style xpg , can't find a trit in the pictures. What charge current does that tiny li-ion require?
EXPENSIVE!
Looks cool, like a chopped down version of their AAA light.
But what is 10110 cell? How does it compare to the 10180 Li-ion?
10mm diameter 11mm long instead of 10mm diameter 18mm long. It is a quarter AAA in length.
I agree with all comments above. Cool little light. Nice being titanium and having a trit.
But where is the trit? Where do you get 10110 cells and how do you charge them? And yeah its a little expensive.
Thanks Don!
I just got the Quantum D2 and that 10180 is so small with so little juice.
I wonder why they didn’t just go with the 10180 rather than the even smaller 10110
Light would’ve been a bit longer but 10180 battery is readily available and familiar to most from Steve Ku’s Quantum style lights and from Peak’s lights.
+1 but more than just little expensive for me :bigsmile:
Oh, I didn’t see it includes the cell. But I would want a spare. And still not sure about charging.
LOL
I consider this a real key chain light.
But I’ve never heard of 10110 before……
Ya If this is confirmed to have an xp-g2, and I can see photos of the trit installed, I am interested.
It also depends how this battery can be charged.
oh holy ***k! :X
i am out.
i am out. i am out. i am out!! :p
So tiny! And Ti! Love it. Cannot justify it even for a second, even wanting too really badly!
Got to be one of the cutest light I’ve seen :party:
Cute little bugger but like everyone says, where the heck would you get an extra 10110? I did a net search and no one has them. Heck, even cnqualitygoods doesn’t sell them!
Just cut a 10440 into 4 pieces
This is a cute little flashlight, but just too small and too expensive to be a serious rival to 16340 lights.
I bet I would loose that one pretty fast
@Horst Horstmann:
Werden bei dir auch so kleine Pakete vom Zoll eingehalten?
Bei mir kam in den letzten 1,5 Jahren bis auf 2 Pakete alles durch - und bei den beiden fehlte jeweils der Aufkleber, was zu welchem Wert drin ist.
Hopefully Ric will offer extra batteries with purchase. After a little research I think some of cottonpickers chargers will work fine with these little cells since he has some moderate amp ones using wire leads and magnets.
But extra batteries is a must to me. $50 is pretty expensive to begin with and I’d be pretty upset of my one and only cell died 6 months down the road and I was stuck with a $50 paper weight.
So Ric can you offer extra cells with purchase?
Going to need a custom charger. 27mA or less charge rate. Charge it higher and you’ll be degrading the cell.
They don’t even give the 10110’s capacity. 10180 is under 90mAh so what is 10110, about 54mAh? 0.5C would be 27mA.
With 20mA low & 300mA high, I’m getting runtimes of less then 10 minutes on high, 162 minutes (2.7 hr) on low.
Took me a while to see it too. It’s in the last image.
The tail has two holes and two scalloped indentations. One hole (the one on the right) holds the split ring for keychains.
The other hole has the trit mounted between the hole and the center (magnet?) post.
Edit: image added to avoid word fumble.
