I have a Quark 123-2 (2 CR123âs, non tactical because I like tail standing lights the tactical can not tail stand) and the preflash that everyone seems to be bent is the lowest mode (moonlight 0.2 lumes) when it comes on it (flashes) Pulses at around 5-8 lumes for less than 0.125th of a second then drops to the sub lum power rating. If you are being all secret squirl then the clicking of the switch is going to give you away more than the slight âpreflashâ
I have to say a an EDC light it has replaced the fenix E11. I like it a lot and I am sure that there are at east 100 people that do not own either light and will tell me that I am wrong.
It is nice having a light that can pull off the range that the Quark series of lights manages to do with the quality of the lights they have. 4Sevens has done a great job on a flashlight.
Still impressed! I had some trouble with mode memorization, even after watching Nutnfancyâs video, and reading the printed instructions, but 4 7s Customer Service emailed me a YouTube demonstration of how to do that, and now its all programmed. I think I have seen the âpreflashâ. A non-issue, IMO. And, the price was right!
A great light! 8)
I received mine today and well⌠i guess there are two options.
Either Iâam stupid (which I admit is a possibility) :exmark:
Or I got useless piece of aluminum. After I insert the batteries all it does is Strobe mode. Full press/half press, doesnât matter always strobe mode :Sp
And I was really looking forward to gifting this to my uncle. I guess now I know why it was for saleâŚ
I just got mine too from the sale. I double checked it and it doesnât make a sound on Turbo or any other mode that matter. I tried several different batteries too. Not sure whats going on with yours. I canât comment on the tint. Tint seems to be a personal thing. I do like the tint on mine.
I would be surprised if they didnât make some attempt to make it right. Their HQ is in Atlanta. They are also on Facebook. I have seen some folks have issues and post it on facebook, and David the head hancho has stepped up and tried to satisfy the customer. Of course buying it at 1/2 price doesnât give you much leg to stand on. Either way, good luck.
That isnât normal but it may be possible to fix through reprogramming it. Have you tried to access the programming mode?
Just twist the head quickly from tight to loose at least four times with the light on and it will go to moonlight mode, wait a few seconds for some flashes then scroll through the modes and leave it on the one you want for about 10 seconds (this will be confirmed with more flashes). Turn it off and on and that will be the memorized mode for tight/low (whichever it was in when you did the programming), then you can do it again for the other position.
Right where the two parts meet. It can be programmed to come on any mode, then when you turn it tight it will can go to a different mode, or you can set it to where when you loosen it, it changes mode. So basically you can set 2 modes. I set mine so that when its down tight, its in moon light, then when I loosen it, it goes to turbo. What ever position you have it in, the tail cap button will activate that position. So, if mine is tight, when I hit the tail cap, its moonlight. Ya dig?
Ok, Making sure we are on the same page. The part that has quark tactical should unscrew at the part where it has a smaller diameter on the tube. So the light should come apart easily in 3 pieces. Tail cap / small diameter tube / head (reads quark tac) . If you have the light pointed forward, twist counter clockwise (left).
BTW. You have to turn both the tail cap and small tube to change modes.
Thats strange. I have owned several of their lights, as well as friends have too. I havenât had a single issue.
Have you tried changing batteries? I am sure you have. Just curious. Where does the sound come from? Head or switch? A spare switch can be had for $9.00.
Yes, thatâs how modes are changed through tightening and loosening the head (part with QT2A and forward) from the body. The switch doesnât change modes apart from in the programming selection, which is why it is called tactical (as you can have momentary on on the modes youâve set).
Mine came stiff too at the connection to the battery tube and head. It will definitely loosen if you get a good enough grip though. I guess youâve only been accessing one of the programmed modes so far (head tight) and that happens to be Turbo mode. Once you get it loose you can program both tight and loose modes to whatever you like. Itâs a really good UI imo.
If you break it loose. I like to put FrogLube on all my gear. Been using it since it first came out. Itâs on all my weapons, lights, fishing gear and the list goes on. It has a very distinct smell. Which I have come to love. Lol. Itâs food safe.
