i actually never got a keygos xml2 yet….didnt know they have one.
lemme take a look right now.
nope…there is no keygos with xml2.
so, if your kd c8 is the xml2 version,
then you have either a very good keygos or a bad kdc8,
cus my kd c8 was noticable brighter than my keygos.
or it could be vice versa hahah, i could have a bad keygos and a good kd , i doubt it though, cus my keygos was king till i bought the lightmall’s and kd’s xml2.
Then installed SMO reflector, and the beam has changed for the worse.
Octagonal crow appeared around hotspot. Behind this bright ring.
Finally installed back OP reflector, and SMO reflector installed on another C8 with XM-L.
With XM-L SMO reflector has a nice beam. With XM-L2 SMO reflector has horror.
Believe me, I love my KE-5. It’s one of the best-driven lights I’ve ever had, it being brighter than all my C8s except maybe for the Lightmalls one (can’t remember now, it’s been about a year), but this little contender is brighter than the KE-5 for darn sure. See for yourself…
KE-5 (left) AK47 Convoy C8 (right), both on fairly fresh unprotected cells
Granted, the KE-5 throws better with a more narrow beam and smooth reflector, whereas this unit has a frosted reflector that is floody, but I tell ya…the spread is beautiful while giving it still plenty of throw.
My point being: for someone in need of a high-quality, no-nonsense C8, I say forget every one of them out there and just go for this guy. It’s hard to say enough good about this light. It would be hard for me to go with any other C8 now. I got it for a friend, and now I want one!
Just checked. And yes, medium does have a super-quiet little whine. No other modes do, though. Hadn’t noticed at all until I checked. Even had to check it by cycling through modes several times to make sure I was hearing that over the heater air-flow. Can’t hear it unless your ear is like an inch away from the head of the light. So that is as close to a negative I can find on it.
The next day after Convoy C8, I received the Nitecore EC25. It is nice compact light, but my hand is constantly reaches for C8.
This is a great light. I already had a couple of other C8, but Convoy surpassed all expectations!
i say u go buy yourself one of these rusty. you can never have more than one c8. maybe try the option with the smo reflector… might be brighter and outthrow your ke-5 now
I’m assuming this is the same as the Convoy C8 at Fasttech, FT says nothing about AK47. Isn’t the another light already called AK47, Trustfire I believe. Anyway, have a FT version Convoy C8 on the way.
AK47 is the name of the 3*7134 driver Nanjg Ak-47 (A or C). Like many thing in China someone decided to use a name that saw somewhere and in this case looks similar to the 8*7135 driver (visually)
Joe - how does it compare to the TangsFire C8 XM-L2 U3 - you just got 2 of those in?
Actually, this is a pretty good deal considering it's well regulated, nice modes w/memory, solid known host, and a XM-L2 U2 (or so claimed). Only downside would be the OP reflector, but only if you wanted max throw out of it - beam patterns with an OP are cleaner. Compared to prices of the TangsFire or FT Convoy C8 offering (only XML's), it's perhaps the best C8 deal around right now.
Nice Find Joe, glad you posted a new thread on it!
