Sportac P60 3x Nichia 219 High CRI Review (now with pictures)
pictures please :smiley:
Cut the sides of the aluminum can into strips that are as wide as the flat area of the dropin, the part above the spring and below the tapered part of the reflector. Wrap the can strips around the dropin to increase the size of the dropin so it fits snuggly into the host. Start off with a long piece 4 or 5 inches long and trim small bits of the length until the wrapped dropin is small enough to fit into the host. You want a tight fit for the best heat transfer. link
Don’t think I need to. I dont hear any rattle and the host warms up fast which means a good contact.
One thing I don’t like is that the tint is a bit too rosy or pink/purple. Hard to describe.
Is this normal for nichia 219 ? It doesn’t show blues too well. Way too pink/purple IMHO.
A pinkish tint is normal for the Nichia CRI 92.
SW45 is the tint, Nichia 219 mean basically nothing more than CREE XM-L.
Now think about that 3C is not a very tint tight, SW45 covers the same space as 4B 4C 4A and 4D at the same time, some will be more pinky some less.
Yes, any lower modes would be too easily confused with 'off'.
Doing some Google searches I see that some show as pink like mine yet others show as pure white.
Tbh considering how much I spent I would really prefer if it wasn’t so pink. If I get it exchanged any chance the replacement won’t be so pink? Was really hoping for a more neutral white.
That specific SW45 tint has a color temperature that ranges from 4260K to 4745K, so based on that alone you cannot have a pure neutral white as the words imply.
Wow pretty big range. I guess mine ended up on the low end of that :frowning:
I’ll email going gear and ask if a replacement if possible. If not oh well. Still better than any other led I have had. I have a NW D40A on the way so guess I’ll see how the tints compare.
Would be nice if it had atleast 1 lower mode. It isn’t too usefull with just the high because it overheats really fast. Cant use it for more than a few min. Have to let it cool down.
I might try putting some aluminum foil or maybe some arctic silver to help with heat transfer.
Define 'overheats' - if you mean it gets hot in your hand, improving the heat transfer between the dropin and the body will make it get hot in your hand quicker. Which is good for the LEDs and the light output. The quicker the outside of the light gets hot, the cooler the LEDs will be running.
Color temp alone doesn't tell you much, look how the color temp changes as you move up-down on this chart...
p.s. Thanks for not allowing hotlinking, flashlightwiki! :angry:
Not so worried about it getting hot in my hand.
More worried about the driver or emitters cooking inside !!!
On an upper post tried saying that with the whole 4A-4D tints coverage
I asked because they don’t specify on their website.
Would have been cool if they used their eagletac output groups like on the D25 etc.
That's only really possible if the outside doesn't get hot. I test little tube lights running at over 4 amps by dropping in a freshly charged battery, switching it on, and letting it run on high until the driver's low voltage protection kicks in an hour later. They still work afterwards.
I guess mine has a bit more 4A, 4D than 4B 4C
In real life it is pretty close to the 4R, 4U and 5R. Really pink with a hint of purple.
Amp draw?
Just keep in mind that at that temperature pure white in true sense of the word is not possible. You need to go to around 5500K for that but there are no real acceptable CRI for that on the market except XB-D 3C from IOS
You see purely white pictures of Nichia 219AT 4500k CRI92 Beamshots because the white balance in the camera is changeable. This LED is known for pinkish light and that is no reason for sending it back.
Yup you are right I think. My galaxy note 2’s camera sees it as pure white and doesn’t pick up any pink. Overall it’s still far better than the ugly green so it’s all good.
