The rattling does not seem to fully stop when the LED shelf is overturned. So what I have done is used around 4 layers of kapton tape on the underside of the reflector. Add to that, the slightly thicker Noctigon plus the wires, it should stop the rattling. I did a test fit, sans the wire, plus half turned the shelf so that it wasn’t fully tightened, and this did result in the head to stop rattling. I am hoping the half turn would be equivalent to the 18G wire I will be using to wire it up.
Focusing the emitter is something I have not been able to do just yet. However, I will be positioning the LED as far into the reflector as much as possible.
Have you seen my build thread on this light? The underside of the shelf was also badly scratched up. About 30 minutes worth of lapping fixed it right up.
Cool, yeah those scratches were really deep on mine, in the middle the gouges where about a millimeter deep and I didn’t feel like removing that much material from an already very thin shelf. I guess it all depends on how heavy handed the dremeling is on each individual shelf.
I may still lap it smooth when I get round to upgrading the heatsinking since then it won’t matter that the shelf is a little thinner, probably wouldn’t matter now either but hey…
Oh but adding extra layers of kapton tape to the underside of the reflector seems counter productive to me. Since that will hamper how low you can sink the reflector over the emitter for focusing. If you can’t bottom out the shelf even when it’s upside down then I’d say it’s not worth sacrificing your ability to focus the emitter.
The stock centering ring is WAY too tall, so I’d take that down first to the point where when everything is tightened up you have the emitter in perfect focus, then see how much you need to shim the emitter shelf to get some pressure on those threads. Do you have some copper pieces/plate you could use to make shims between the bottom of the emitter shelf and the body?
I coiled some copper wire to act as a spacer but that’s obviously not a good solution, just lets me tighten the shelf threads up.
Hmm, I decide to come back on and the first post I read has this ‘Modder’s Dream’ in it… nice. I guess I need to polish off my international credit card
Anyone measure the throw with a dedomed XML-2 U2 1C in there? That reflector really looks like it should throw, and the beam shots show it as well.
I meanwhile got mine, too, and just did a driver mod like LinusHofmann in #98 (desoldered all components from the board to simply use it as contact board, and get in a NANJG105C 3.0A with custom firmware) and of course used better wires. I'm quite happy with it. My Skilhunt K30GT (firmware modded) blasts it away though :)
Hehe not surprised there!
Out of interest did you also shorten the centering ring to focus up the emitter better? It’s really far off optimal on these when stock.
I’d be really interested in seeing some beamshot comparison photos between these two lights if you get a chance.
Oh that’s interesting maybe the tall centering rings aren’t a problem across the board. If you get the light apart again I’d be interested in a measurement of the emitter centering ring to see if it’s a shorter one. Wouldn’t surprise me to have some variation on these parts.
I Added an R100 resister and got 4.1A. I could smell some burning at first and saw some smoke curling out the top of the pill. I don’t know if it was just old flux burning off, but I used it for a few days like that with no problems. I intended to use the stock driver as a contact board anyway, so I waited to see what would happen.
Nothing else happened, but the board has since been stripped of components. You could try running it for a while outside the light and see for yourself.
OK, I’m seeing a few places to order this light from, which is the best mod host so far?
Anyone order and receive the DX model yet?
Is ShenZhenWholesale the only seller with an unbranded model?
