Hi there MrCG I hope this is of some use.
There are a couple of inexpensive small flippers at FastTech.
I’ve just got a SanRenMu 7034LUC-PK Under $10 and the fastest flipper that I’ve tried, faster than my Kershaw Chive Speed Assist by a long way. It does make your finger sore after an hour or so of playing. :bigsmile:
8Cr13MoV blade 68mm, 2.68” long
All the usual SanRenMu qualities - build quality, fit and finish and strong lock-up. The scales Imthought were going to be softer tike rubber but they are hard and durable translucent plastic.
The other ones are a pair of SanRenMu’s with different finishes - 6026LUI-SGI
. Same seriel number but different SKU
They have 8Cr14MoV blades 53mm, 2.09” long. $8.06 at FastTech.
I’ve got one on the way, the blue/grey/black one. If you don’t like the coating I’m sure a spray with something could turn one into something “custom”.
I’m staying with FastTech because I’ve bought from them and am buying from them, the wait is worth the saving in £ or $ for me anyway.
. Harnds Nyx lookalike of the Kershaw Brawler but with the reverse tanto blade. 80mm, 3.15” blade in 8Cr14MoV. Assisted opening. Under $10.
I have the sanrenmu 733. Super speed flipper and perfect ergonomy of the handle and blade. The handle is perfect for the hand and the blade have even 2 positions for the fat finger.
