And now I got an email saying they refunded me and I should check paypal in 48H
Responed to the email and contacted banggood here. Hope to get this solved and just get my head charger.
This is becoming one of the worst slowest order on banggood for me.
Can’t get mine apart! I’m going to take it to work, see if I can get into the head. I really need a DrJones driver in this light, it would make it almost perfect for me.
Got mine today, and no charger head either, even though the label on the plastic bag said "SKU104954 with charger head"
I like the design, quite compact and nice.
Heat transfer to the body is very good; there's no pill, the LED MCPCB sits on a shelf that's integral part of the body.
Measured 2.5A / 0.8A / 0.2A; quiescent current is only 1.3µA, quite nice.
I don't like th UI though: When off, a not too short press (about 1/3 s) is required to turn it on. When on, short presses switch through the modes (H/M/L), and a quite long press (a bit more than 1s) is required to turn it off. I haven't found strobe or SOS yet. There's a red indicator LED opposite to the switch for low battery indication. Also med and low have an ugly ~170Hz PWM.
Unfortunately there's not enough space in the head to put a NANJG105C there, so modding with a better UI will be difficult.
Couple of things about this light, previously though no protected batteries would work but the Keeppower Panasonic 3100, 3400 and Xtar 2600 work, probably any battery with a Seiko protection circuit. Protected Banggood/Wallbuys/Fastteck Panasonic, Sanyo, and Samsung don’t work.
This is one of my favorite lights, the only thing I don’t like is the power button is too easy to push while carrying in a pocket. Was thinking about getting a stainless steel washer and gluing it around the power button for protection, any suggestions. Know I can unscrew the head a little to break contact but not really wanting to do that.
Same here.
I have protected 3400mAh panasonics recently bought from wallbuys and a set ordered a couple of months ago from fasttech. Both fit without any problem or trouble with tightening.
