I won this flashlight from the cnqg giveaway, so it’ll be interesting to test it when i receive it. I might need a new charger for the battery as well, since i don’t have one with such low current…
Maybe a tp4056 charging module could be used? Not sure what value to use on the sense resistor though.
When I bought the quantum D2, I ordered 2 extra cells for it, but unless you intend to put the light through heavy use, 1 cell might be enough as they only take about 20 or 30 minutes to charge.
I only need 1 cell for my occasional use of this light as it is a backup, and if I’m in work I have a Solarforce L2M and Armytek wizard pro on me.
Fstoplights have 10180 cells. I got my AW’s there. Great quality cell. After light, occasional use and 2 months after a charge, the AW 10180 showed 4.08 volts.
P.s. The bottom of the plastic wrap on the cell had to be cut off to allow the negative contact of the cell to make contact with the flat base inside the quantum D2.
Well, I wanted to pull the trigger on this light so bad but with already having the latest versions of the DQG AA and DQG AAA and with all the hassles of getting lithium cells from overseas, I just couldn’t do it.
I guess I can live without it. If anyone gets one let us know what you think.
i have ordered tp4056 boards from ebay, and hopefully i’ll find some smd-resistors in my electro-junk that i can use to get a tiny charge amperage for the 10180 batteries.
don’t worry about current, you can charge it in normal charger for Li-ion batteries, it will not brobably last you 1000 times charge but only 999 times… but you will charge them faster
Charge it in a normal charger and you degrade the cell. Battery capacity will progressively be reduced. It already has a tiny capacity to start with.
For a non-diy charger get a quantum DD / D2 10180 charger. Illuminationsupply was selling them a couple days ago but listing just disappeared.
