Thank you for that great flashlight suggestion, I think this one might be it for me. I’m gonna need the light, 2 batteries and a charger so its about $60 not including shipping so I’m gonna put this on my wish list.
I’m gonna wait and see if anyone might find one that’s almost as good for the budget if have, if not I’m gonna get this setup.
Keep in mind the heat generated on high will be a bit much, but think of it as a manual turbo, and heat build up faster if you tailstand a light vs in hand use
That is going to be quite difficult to achieve and acquire quality items. Next to impossible if you want them within 2 weeks. You may want to save up and increase the available budget, or increase the amount of time in which you wish to receive them after ordering. USA shops are going to be a bit more expensive, but you’ll get the items within a week. Asian shops are going to be less expensive, but the shipping time could be anywhere from a week to 7+ weeks, depending on specific vendor and their shipping method.
I would suggest avoiding using the battery charger that came in the bundle you purchased. It may be a decent charger, or it may be a piece of junk that will cause a potentially deadly explosion in the near future. To be on the safe side, set it aside and buy a charger of known good-quality with the proper charging method and safe charge cutoffs. The risk is not worth saving the $8-15 it costs to get a good charger.
And I implore you to chuck that ultrafire battery in the trash ASAP. Absolutely not worth the risk for the $5-10 in savings.
10+ everything unknown00101 said.
Ultrafire / _any_fire batteries are often counterfeit, poor quality, can be dangerous. Flashlight kits on ebay that include a battery & charger send the cheapest battery & charger they can get. They are often dangerous straight up. Seen several reports of the chargers dying or blowing up.
I recommend Starry Light SA-22 $24.99 - 880 Lumens, 4x AA, cree XM-L2. USA seller so you can get it quick. You can use alkaline AAs until you get ni-mh rechargables.
In li-ion only get batteries with quality protection. Panasonic NCR18650PF Protected (usa) Imho others should really not be suggesting unprotected li-ion. Mtnelectronics is run by RMM (Richard). Ships fast. Answers questions / provides suggestions on his blf sales thread. Just check that your light isn’t known to stupidly have problems fitting protected batteries. In that case IMR / Li-mn batteries would fit, they are ok unprotected. Panasonic CGR18650CH is IMR. Likely the same battery relabeled with a button top. I’d go button top.
Isn’t every battery linked unprotected, don’t you think he should be buying protected since he’s kind of new. Maybe all of the lights linked have drivers that stop at low voltage. The XinTD and Convoy are both great quality lights for the money. You will need to order from a USA company it you need it in 2 weeks or less so Fasttech is out.
Imho nearly everyone should get protected. Very little reason not to. Li-ions were never meant by battery manufacturers to be sold or used unprotected.
From this thread. Overdischarge protection is very important too but was talking about flashlights which had that in the driver.
Only those that want to push more amps then the overcurrent protection allows & want to risk it for the extra capacity over IMR should really be using unprotected. Need to be very experienced, knowledgeable & practice extra safety precautions. Without protection you can do internal damage making them dangerous.
Before RMM brought us his evva seiko protected panasoncs, quality protection was excessively expensive. $13-14 for one keeppower 3400? $4 extra per battery just for their name? $17 Orbtronic, $20 Xtar, $21 RediLast, $25 nitecore. All the same NCR18650B cell. At $9.75 for evva, little need to get mystery protection or unprotected anymore. Wallbuys had keeppower 3400s for $9.60 but they have raised it now. If you have family you live with, even more reason to want quality protection.
IMR / Li-mn are ok unprotected. Takes higher temperature to reach thermal runaway, aka “vent with flame” (or explosion if inside flashlight). IMR / Li-Mn 250°C vs li-ion 150°C. Doesn’t happen very often but that doesn’t help the people it does happen to. Even major brand name mobile phones & laptops with li-ions that would include quality protection have burned.
Ordering from FastTech I’ve had the vast majority of orders arrive in less than 2 weeks. Many within 8 days. Make certain to select the following shipping method “USPS First-Class via Hong Kong Post FREE (8 to 14 working days in transit typical)”. Just note that you may not have the same results as me.
$23.28 [Flashlight & Charger] (Use Coupon at FastTech, enter when you open the cart click “have a coupon code?”, Coupon Code: BLF)
$20.89 [2x 18650]
_
$44.17 Total (Includes shipping costs).
To me keeppower charges too much for their name unless you find them on sale. Since RMM’s evva 3400 is out of stock Panasonic NCR18650PF Protected 2900mAh $8.75 seems to be the next best deal for seiko protection (same as evva 3400s) if you don’t want to wait.
I suggest you use a cheapie AA torch for a while, and figure out what you need to spend to get a few good batteries (I guess 18650s) and an appropriate charger - and then find a flashlight that will serve your purposes.
You budget at the moment will cover a few good batteries and a charger, or a good flashlight - but you would be doing well to get both.
First is able to run on any AA batteries. very good price on two nitecore chargers that can be used for NiMH or lithium so if you decide on different battery chemistry this will be useful as you will only need one charger for what ever chemistry you choose. The convoy lights are a good light in the 18650 format, and a quality protected 18650 for good price. Good prices and fast shipping from quality vendor.
I was going with one battery and didn’t know the charger was out of stock. Have bought 2 headlamps from IS and the shipping was only about 3 dollars for me and I’m on the east coast. Buy these , sell the other 3 for $7 each to make your money back and you can use that until you save a little more money.
Yes, I want to repair my old light with new components. I’m just really new to this so I need to learn the basics about drivers and emitters and how to wire them. I have been reading around but there are so many links and so many options I just don’t know where to start.
I ordered this how did I do?
I went over my budget about $20-$25 if I’m willing to spend $40 on an OK quality light I might as well spend an extra $20 for a far better light.
Thank you guys for all the great recommendations. I do plan on buying more lights and saving money ordering from china sellers. I would like to use my old light that’s broken as a donor and order parts and build my own light from scratch.
I read a greatly written post on this a while back but have no clue how to find it again
The switch is easy just try a paperclip to go from battery to body and see if it lights
The LED is trickier, but if you have a multimeter with diode test try it on the LED, it will only light up with a faint glow so do it in a not very brightly lit room. You can also try a resistance check on the switch
Circuitry is harder, you can try measuring LED voltage with the light on see if its getting anything, since you only have one light you can’t try other circuits on it
Also make sure your battery is not dead, what you have now is known for being junk, you can try 3AA batteries in series, that will light the LED, just not super bright for super long (NiMH is better, alkalines don’t do high current well). You can also use 2 alkalines or 3 nimh to test just the led, wire them in series, they can’t put out enough current to damage it.
The battery voltage should indicate its charge (but those junk batteries sometimes give high voltage when they are dead), less then 2.5V get rid of the battery and never try to use it again (it could explode), 2.8-3V is dead, 3.8V is about 40% charge, and 4.2V is filly charged.
Out of what you have the battery is the weakest link, the charger is the next weakest,then the switch and circuitry, its unlikely the body would be the problem, and its highly unlikely the LED is toast, Cree LEDs are almost bulletproof
The light you bought is very throwy, the batteries are good quality and the charger is widely used by many BLFers who apparently have no problems with it
Protected would be better, if it got shorted in a toolbox it would prevent catastrophic failure, but as long as you know how to use li ion batteries safely you won’t have any problems, i have no protected and have used hundreds of li ion charges of flashlighting.
This hold an 18650 very effectively http://www.walmart.com/ip/Coleman-Match-Holder/13848642
