To tell the truth, I am not even that excited about DQG any more. It will for sure has lower output, it is wider. The only advantage is that it takes 26650.
But anyway it is coming…
I ordered one last week.Like yours but at 4.5 amps….not as brave I guess!I am very excited about this light….until Richard gets the BTU shockers in!His shop really is turning into THE flashoholic shop for the US!
I think that the reason for the way the beam is is that the Carclo 10507 optic is slightly mismatched with XP-G2. I found a thread over on CPF awhile ago discussing that.
I know you said that you have 16 7135s and are using 20R battery, but have you measured current at either the tailcap or going to the emitters? Just curious about that.
Outside of the flashlight it pulled just shy of 6 amps on a fresh 20R... I don't recall the in flashlight test (don't have my notes by me) but it wasn't too far behind.
RAW74: It isn't too late to crank it up a notch! I built your driver last night but haven't installed it yet...
I am tempted but I’m sure 4.4 amps will be amazing enough?I will also end up using this for several min. on high at camp, probably not in the best frame of mind to know when to step it down.What does a melting optic smell like anyways?On another note, when do you think the protected 3400’s will be in?Or the BTU shockers?Or the……
Sorry, I get excited about all the new projects you have for your store.I hope you had a great Holiday Richard, and look out for that Garry Bunk fellow.He will have you spending too much time bothering Homedepot employies!
It seems to act like if you made the front face of the TIR thicker, makes the spot bigger, more spread out (hold a magnifying lens in front of a regular flashlight, same effect). The 10507 has little inverted cups/divot-things in the centers, a lens doesn't affect that one as much as the others with flat faces, like 10508 & 10511. 10511 has a nice small spot and a smooth outer corona, a lens really makes that one look not so nice. Without a lens it's the closest of the 20mm optics to a single LED in a conventional reflector.
edit: A lens does the same thing to single-LED TIRs as well, it's not specific to anything with these triples or any certain LED.
I think was talking about the emitter type (i.e. XP-G2 vs. XP-E2). The lens is locked into alignment by the alignment tabs on the lens/MCPCB so you really can't change that.
That is true I guess Richard. The beam pattern is very different from what I usually see with my other lights. That is very interesting and refreshing!
The listed price is definitely a very good one. Just list all parts you need for this and add them up…
Yes, that’s correct. The 10507 was designed for the XP-G, but the beam angle (or whatever it’s called) for the XP-G2 is slightly different than for the XP-G, which apparently causes this. From what I’ve read, it’s only visible close up though, like on white walls :)…
But, ack, you made me look “over there”, to find the link:
You are welcome for that!
I am also thinking to get a 10508 in the next order from Richard.
Richard, is it easy to swap the optics? I haven’t tried to open it.
