The Xtar MC1
21 posts / 0 new
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 1 year 6 months ago
The Xtar MC1
I got one of these..totally blown away by what it could do http://www.xtarlight.com/05-chanpin/p-001-1.asp?styleid=292&style=New%20...
Quote:
Features: ● Reverse-polarity and short circuit protection circuit ● Three-stage charging and 0V battery activation ● Micro USB port to supply power for the charger ● Adopts IC temperature monitor, avoid over heat ● Small charge current when start to charge ● Compact size portable ● Low heat design Input 5.0V DC/500mA Constant current output 500±50mA Termination Voltage 4.20±0.05V Termination Current <40mA Apply to 10440/14500/14650/16340/17500/17670/18350/18500/18650/18700/ 22650/ 25500/26650 3.6V/3.7V Li-ion batteries
Well I have been eyeballing these TP4056 USB micro USB PCB modules, well wouldn’t ya know it…on my MC1 it fell off my desk and the micro USB connector on the PCB broke…so I opened it up to investigate…found a chip inside that had 57b8 on it (the charge controller chip)…couldn’t for the life of me find that IC…until now. Found the TP4057, which in the data sheet…has 57b8 all over it! This data sheet is mostly Chinese, this one is better
Then I found this online
http://www.ebay.ca/itm/Dual-TP4057-Li-ion-Lithium-Battery-1A-LED-Charging-Board-good-/370951123671
and this
http://www.icstation.com/product_info.php?products_id=3202#.Ute5B6xfZpk
So in effect the EXACT same thing that runs the MC1 by Xtar (some of the BEST Li Ion chargers out there) with some wire, some tiny neodymium magnets you could in effect build you a charger like this
or with a cheap single cell battery holder like this
http://www.fasttech.com/products/1009/10002233/1191500
And voila you have a TOP OF THE LINE battery charger for pennies on the dollar, and by the way..that module above is a dual charger!
Any of you OSH Park board masters want to whip up a pcb, we can get bulk tp4057 from here
http://www.amazon.com/SOT-23-6-Battery-Reverse-Interface-Protection/dp/B...
Edited by: WarHawk-AVG on 01/16/2014 - 05:56
MountainKing
The hard part is knowing where to solder the wires!
Never ever forget and forgive. Niwal**er new kid on the block trying to act tough.
http://budgetlightforum.com/node/24847
Do not support this brand.
DINODIRECTSCAM COMPANY. DO NOT BUY
http://budgetlightforum.com/node/11324?page=2#comment-254983
WarHawk-AVG
Oh yeah...soldering it back on for sure...but wouldn't mind having a DIY project and pump out a bunch...especially since they are alot better than the TP4056, which is good...
Ledsmoke
Ledsmoke's picture
Nice find!
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
 I do not think that the BLF-community ben
Helios-
Helios-'s picture
Last seen: 2 years 4 days ago
TP4057 has been used in a few chargers. Original ml-102 used dual tp4057 too.
Why do you see it as better then tp4056? TP4057 doesn’t seem to have a solid CC phase, current starts droping nearly from the start. Not bad for batteries but it is slower. TP4056 on the other hand does give a real CC phase. HKJ ml-102 review. TP4056 review.
Note that the ml-102 curve is a 2600mAh cell and the tp4065 is a 3400mAh. Extra 800mAh and its still faster.
Counterfeit 18650s, 2,<a href=“http://
WarHawk-AVG
Helios- wrote:
TP4057 has been used in a few chargers. Original ml-102 used dual tp4057 too. Why do you see it as better then tp4056? TP4057 doesn't seem to have a solid CC phase, current starts droping nearly from the start. Not bad for batteries but it is slower. TP4056 on the other hand does give a real CC phase. "HKJ ml-102 review.":http://budgetlightforum.com/node/12462 "TP4056 review.":http://budgetlightforum.com/node/13913 !http://lygte-info.dk/pic/intl-outdoor/Charger%20ML-102/ML-102%20%28AW186... Note that the ml-102 curve is a 2600mAh cell and the tp4065 is a 3400mAh. Extra 800mAh and its still faster.
I guess mainly because I have seen the TP4056 in those cheap USB modules, and the TP4057 in the Xtar...
The slow current charge on overdrawn Li ion could help prevent high stresses on heavily used batteries
Helios-
Helios-'s picture
Are you planing to repair your Xtar MC1? Seems like a nice design. Slider. Plug at the end so a couple can actually used side by side (unlike the ML-101 / 102). Though they advertise it as compatible with 10440s when the current is too high.
WarHawk-AVG
Oh yes going to repair it...absolutely
WarHawk-AVG
The Miller ML-102 is a TP4056, not the TP4057
Miller ML-102 Version 6 (that is shipping now)
The markings on the chip inside the MC1 have 57b8 on them, clearly marked TP4056 on the Miller (even though you can’t see it in my lousy photo)
WarHawk-AVG
Update on the re-repair
TP4056 charge module (notice 222 resistor on R4 [2.2K ohm] limiting current to approx 500mA)
Above module soldered to slider rails
I put a tiny bit of clear silicon as a conformal coating over the board to protect components from shorts
Helios-
Helios-'s picture
Clear 18650 battery shrink wrap works great to cover TP4056 boards.
Any plans to add the ntc thermistor to the board?
WarHawk-AVG
no need to, 500mA~ current, doesn’t get hot at all…plus I use it as my spare charger at my desk at work (I have a Nitecore i4 at home [along with 5 Miller ML-102’s V6’s modded to 500mA charge as portable power banks for the kids kindles])…so if I need to charge one of my vaping batteries, (I do carry spares) I keep an eye on it
Now that you mention it…daggumit I shoulda used some clear heatshrink…dangit
Bright_Mike
Last seen: 2 years 1 month ago
Great post war hawk. I have bought several 4056 boards over the last few days and was wondering what to do with them. My specific concern was attaching the batteries to the wires. How do I do that properly, without a short, also where do I get neodymium magnets?
Wonder if you could attach a 6V 300ma solar panel?
Not sure what Mountain King was asking, but the place to connect + , – to battery is marked on board I believe.
Rufusbduck
Rufusbduck's picture
Last seen: 7 months 1 week ago
I’m thinking of trying to squeeze one of these(input) and a boost charger(output) into one host as a rechargeable backup for Istuff.
Scott
scottyhazzard
scottyhazzard's picture
Last seen: 2 years 6 months ago
It would be very cool to put in a host. How would you put it in a host BTW? How would you put a charge circuit in and keep it waterproof and not risk having short circuits?
"Those who hammer their guns into plows will plow for those who do not."
WarHawk-AVG
I got 3mm neodymium magnets from FT, just can’t solder to em…the heat kills the magnetism
I’m thinking some sort of electrically conductive epoxy would be best to bond the wires to the magnets
http://www.amazon.com/Nickel-Electrically-Conductive-Adhesive-AA-DUCT/dp/B00EPYCUDC/ref=pd_sim_sbs_indust_10?ie=UTF8&refRID=155HX4WKK6XG8QNBY111
This is why I saved the housing and sliders of the MC1…inside the housing where the positive and negative terminals just tacked down the leads going to the TP4056 and then soldered the other ends to the USB module making sure polarity was kept of course, then heat shrunk and voila
Rufusbduck
Pot it into the head with only the ports showing. In the past I’ve made a wax casting then a mold to cast the circuit in to make it removable. For the length of this I might need to add a finned section for it to be useable with a custom pill reflector.
Scott
WarHawk-AVG
Well…killed my first TP4056 charger module the other day (oh well..out $1.15)…might need to put a Schottky diode inline to prevent reverse polarity, but if I do that, the voltage drop across the diode will end up make it undercharge the battery…one simple slip of the mind and not paying attention and kaput.
Oh and yes, the clear heatshrink tubing works AWESOME at covering the little board!
pilotdog68
pilotdog68's picture
Warhawk, any tips on getting the mc1 open with minimal damage?
HarleyQuin
HarleyQuin's picture
Last seen: 1 year 6 days ago
I’d like to know as well.
The MC1 looks so tightly put together, is it glued or clicked?
Help is much apreciated.
Oshpark Boards:
HQ ProgKey: Universal Driver Programming Key . Boost: HQ 15mm/17mm programmable boost driver with ATtiny13A
46mm Triple-Channel: BLF SRK FET v3 . 17mm Linear: HQ10D / HQ4D / HQ4S . Contact Boards: 22/24/26mm
HarleyQuin
Just to add my experience.
I opened it with an exacto knife, which wasn’t fun, took it’s time, but worked out well.
The case is neither glued nor clicked. I believe the correct term is welded (with heat).
So cutting is the only way and you have to cut quite deeply.
Oshpark Boards:
