hmmā¦ out throw STL-V6?? whoaā¦ not many budget ( under $35) stock light can out throw STL-V6
edit - n/m OP says STL-V2ā¦ in that case Iām not surprise then, as itās more flood than throw
I meant the original 3.5 amp-driven V2 with 1 x XM-L, not the V2 3 x XM-L of today. The V6 model throws about the same as the original V2. And this little guy will put out a tighter beam that will go toe-to-toe with it. That is high praise, indeed.
I believe it is a true SS bezel.
I stumbled on that naming issue while looking for my first thrower. So many pages and reviews referencing each as the otherā¦ bleeh.
Just got a fresh Sanyo 2600 to stand up in there and now it SCREAMS in brightness like before. Wowy! But I still havenāt determined if itās direct-drive or the brightness drop is from a waining 26650. We shall see.
I love it. Beastly thrower and very nicely made. Use a good cell and it should treat you right. Very tight beam, tightest Iāve seen an XM-L(2) have.
Thank you.
Itās the second light I ordered because of your impressions. The other one is the HD2010 XM-L2 T6.
I havenāt received any of them yet so Iām very excited.
Thank you.
Speaking of that one, it is between these two that I canāt quite decide which throws further. They throw differently, that is for sureāthe 2010 with a much fatter and wider beam having an almost neutral tint. But they both throw like heck. Tell me which you think throws further when you get them. I can only test in the city at present and just canāt tell a difference at the longest ranges. But they are both dynamite lights. The Yezl looks slightly cooler.
And thanks for the vote of confidence in my judgment!
Y3 is sold out already and Wallbuys was the only store that carried them. I hope theyāll restock soon.
30/01/2014 17:11 Departure from office of exchange HKHKGA
30/01/2014 10:30 Departure from office of exchange HKHKGA
29/01/2014 10:04 Item accepted in network INTERNATIONAL POST
:party:
yesterday i have the yezl y3
10 days buy- at my home very good from wallbuys!!
good pakkage too
ist a great light.
Itās better than a HD2010 with slightly larger reflector.
the spill is greater at further distance, but I dare say as much light intensity at a distance, it highlights a little wider.
the color is what I call lemon white / yellow but I find it very good color for this.
completion of the flashlight is good and you feel a little more grip in the hand than the HD 2010
the memory button on the body is very valuable.
He is about 1-1.5 cm longer than an HD 2010
I have already done the spring mod also with the HD2010 today.
the hd 2010 I have a very noticeable difference! do!
the driver is 2.5 amps according to site wallbuyss
someone has already modded this flashlight?
I think it interresting for a good 3 amps available.
can we soldering chips ?
Wallbuys still has the one that comes with two extensions to run 1/2/3x26650, is the driver a boost driver? Because in the specs sheet it says that the input is in the 2-cell range.
where did you guys bought the HD 2010? I got this light few days agoā¦ definitely have smaller hotspot than HD 2010 but the head is about the same when you put it back to back with HD 2010
the driver seems to be modable with simple resistor mod
I got my HD2010 from Willbuying (3-mode, XM-L2 in black).
No, I can say that the flashlight on my walk of + ā20 minutes do not get hot.
if I would perhaps modding maximum 0.5-1 amp? now it is 2.5 amps according wallbuyss
That doesnāt sound good. Since itās so bright the actual current to the emitter is probably more than 2,5A. And it should get quite warm after 20 minutes on highest mode.
Well, letās not assume too much; this isnāt a namebrand light, so we donāt quite expect the same measures that Fenix or Olight would take to build the light. And yet, it is very well built and performs well even by their standards ā with the same being said over various people who bought them. All seem to have gotten the same, nice little powerful light. That says something.
If it were badly heatsinked, output drop would be an issue, but I canāt see that it is. No, itās not a modded toy, but for a budget light, Yezl has exhibited excellent care in every respect so far as I can see. Iām surprised with how solid it feels and how nicely it performs. Like I said, poor manās TN31.
Anyone know if the Type A (1*18650) and Type C (1/2/3 * 18650) versions are the same, just with more battery tubes?
(ie, can I buy one of each and have two 2*18650 Y3s?)
